Timing chain for cam install?
Old Nov 27, 2004 | 11:27 AM
JasonG's Avatar
Default Timing chain for cam install?
Which one? There are so many to choose from I'm stumped on which one would be the best as for performance, peace of mind and cost. JWIS, SLP, Comp, Rollermaster? Opinions are allways welcome. Thanks.
JasonG
Old Nov 27, 2004 | 12:01 PM
5POINT7's Avatar
Not sure if this will help or not, but I recently purchased a TSP 231/237 cam with a Rollmaster Double Roller (non heat treated). Trevor from TSP recommended it.
Old Nov 27, 2004 | 12:04 PM
01_SuperSlow's Avatar
JWIS chain. It's used in the C5R engines that run the 24 hour Lemans in France, enough said.
Old Nov 27, 2004 | 12:41 PM
cyphur's Avatar
What kind of cam are you going with? A double rollmaster is a sweet chain indeed, but some think its overkill. A JWIS would do you just fine on most cams.
Old Nov 27, 2004 | 12:48 PM
JasonG's Avatar
I have a MTI G1 on the way. 228/232 .588/.575 113
JasonG
Old Nov 27, 2004 | 05:32 PM
Argon Z's Avatar
is th JWIS chain with stock sprockets good?
Or are you supposed to replace the sprockets?
Old Nov 27, 2004 | 05:45 PM
Silver_Whistler's Avatar
JasonG
ive got a MTI C1 cam and im using an SLP double-roller timing set. Works great i would reccommend it to anyone going with a new cam.
Old Nov 27, 2004 | 06:10 PM
bigdsz's Avatar
I'm going with the Comp adjustable, because I have a March underdrive pulley and supposedly there have been some fitment issues. Just out of curiosity what would be the reason for going with the non heat treated Rollmaster over the heat treated one?
Old Nov 28, 2004 | 12:15 AM
PREDATOR-Z's Avatar
J-WIS. here with a March pulley. No issues at all and no need to replace sprocket if it is in good condition.
The reason a lot of poeple use double roller is that they are cheaper than J-WIS ($150) and are adjustable (advance/retard).
No issues on the oil pump either. I spin till 6600 on an XE-R Stealth II.
Old Nov 28, 2004 | 12:20 AM
5POINT7's Avatar
I asked Trevor at TSP the same question before I bought mine, he told me that the heat treated was basically for seriously high hp, big cube, FI, etc applications. I think he quoted something like over 600rwhp would require the heat treated. That's why I ended buying the non heat treated.
