fm14 question
Old Nov 28, 2004 | 05:21 PM
pdd's Avatar
pdd
Default fm14 question
hows the drivability with this cam? any1 daily drive with it? hows yr gas milage?
Old Nov 28, 2004 | 05:30 PM
99BackNBlackZ28's Avatar
Looks like you have an F11 as is...I dont think gas mileage is going to change much between the two...just my opinion.
Old Nov 28, 2004 | 08:24 PM
pdd's Avatar
pdd
great cam the fm11. want to go alittle bigger and the fm cams rock
Old Nov 28, 2004 | 10:29 PM
66deuce's Avatar
just curious,how's the idle and drivability with that cam?
Old Nov 28, 2004 | 10:38 PM
pdd's Avatar
pdd
VERY GOOD, its on a 114lsa
Old Nov 29, 2004 | 07:06 PM
pdd's Avatar
pdd
any1 using this cam???
Old Nov 29, 2004 | 07:09 PM
cyphur's Avatar
i'm probably going to run this cam in the spring. should be pretty strong. drivability should be just like all of allan's creations....great! i'll be going with it on a 112 tho since i'm a m6. i talked to candy about this cam right before they released it and it sounded VERY promising. not quite the RJ cam, but a good step beyond the f13. check out the dyno section, some guy in an a4 freakin pulled 422 unlocked thats nuts. can't wait to see some m6 numbers.
Old Nov 29, 2004 | 08:13 PM
pdd's Avatar
pdd
i ordered the fm14cam as well on a 112. cant wait till spring
Old Nov 30, 2004 | 05:49 AM
Slowhawk's Avatar
LS1Tech Sponsor
I run Cams close to that but different cut's on the lobes.The idle is good at 900rpm,drivability is great,peak hp is at 6300rpm ect. Can't say your Cam will be the same but should be close.
Old Nov 30, 2004 | 11:26 AM
BlueSix's Avatar
Just curious as to why you didn't have alan grind you a cam that is custom tailored to your needs?
Old Nov 30, 2004 | 02:39 PM
pdd's Avatar
pdd
when i talked to allen and gave him my specs he recommended that cam
Old Nov 30, 2004 | 05:24 PM
cyphur's Avatar
spring won't come fast enough for me since i plan a cam swap then, lol.
Old Nov 30, 2004 | 09:31 PM
BlueSix's Avatar
That's a good enough reason. It's nice to see that some of Alan's "off the shelf" cams will also work very well with aftermarket/ported heads. Good luck on your final result.
Old Dec 1, 2004 | 12:16 AM
cyphur's Avatar
quite a few of allan's cams will work well w/aftermarket ported heads.
