Why use larger cams on larger motors?
I am wondering why someone would do this? In theory, if you increase port cross-sectional area, valve size and flow in proportion to the increase in displacement, you do not need more duration. I understand larger valves might need more lift, but it seems like more duration would be necissary.
Is this done because intake manifold and port runner cross-sectional area is too hard to change on modified cars, and you need more flow?
The larger the cubic inch of the motor, the more duration it takes to turn the same RPM. More cubes "swollows" up duration. Compression does the same thing. A 224/224 cam in a 346 motor may turn 6400rpm. The same cam in a 427 will probably only turn 5500-5800rpm.
A larger engine does need more flow but doesn’t necessarily need a “larger cam”. “Larger cam” is generally interpreted to mean some combination of more lift, duration and overlap, and to lead to increased power at higher RPM. A larger engine may be unable to benefit from a larger cam due an inability to safely reach higher speeds. Unless you are adding cylinders, the steps taken to increase displacement tend to reduce maximum safe engine speed.
I should have specifically asked about these engines only. I know they need to breath, but if you increase flow rate in proportion to the displacement increase (with larger valves, runners, ports, etc) I don't see why you would want more duration.
Unless you simply can't get the flow you need out of heads designed for a 5.7L motor. In which case I might wait for the LS7...
More displacement eats up the cam, requiring a "larger" cam for higher cube motors. More cubes = needs more air. Cams open the valves, not heads, you know that
Doesn't matter what the head flows if the valve isn't open long enough for the stroke/combustion cycle.
ALSO, port cross-sectional area isn't the end-all be all some think it is. Port DESIGN is tantamount, as AFR has shown with the smaller ports and runners, yet keeping the velocity up has enabled them to put out some killer numbers.
Whats the point in gouging out your heads and block at the costs of thousands of dollars, only to use a small cam that won't let it breathe?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
What he's saying is if you have a 350 ci engine with heads that flow an average of 200 cfm, and you have a 700 ci engine (double the size for simplicity) with heads that flow an average of 400 cfm, then theoretically they should behave the same with camshafts of the same duration.
I suppose if you had heads that flowed @ 600cfm you could acheive that. Since most good ported heads flow ~300+. The cam would no longer be the deciding factor. However....since heads aren't about to flow like that....its a moot point. Thats kind of why I made the above post, b/c its not something that you can change right now.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If you had cylinder heads that had intake and exhaust ports the size of 55 gallon drums, it would do no good if the valves were welded shut.
Thanks for the responses.
And BTW, I wanted to know the "perfect world" answer because I am wondering if it is worth waiting for the LS7 vs. a current LSx 427 (if the LS7 is indeed going to be a 427 at all). The new engine will undoubtably have bigger valves, ports, runners, etc. and be close to "perfect" for its larger displacement.
cyphur_traq, DOHC motors of varing sizes don't really change duration, so I don't think thats true.
I don't know if any of us has all the answers, but as far as waiting for the "427' if it is indeed that, that would be an interesting wait. I think that some parts would be very affordable, as the new LS2 intake most certainly is, as well as the 90mm TB. And they would be OEM quality, not a bad thing (Usually). If I re-do the 395 stroker I got to a 4.125 bore W/ Darton sleeves at around $3,000.00 or so, I wouldn't be a happy camper if after I am done G.M. decides to come out with a non-C5R-4.125 bore block for around the same price as the LS2's 4.00 bore ($1,000.00 or less!). Obviously, this would be a net loss of about 2 grand for me/us
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
I can't comment on DOHC stuff, I don't know **** about it. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
In a perfect world, lots of things would be possible. I was referring to the LS1 series. LS7 is different, I haven't read up on it much, so I dunno what will happen. But right now, as it stands, LS1 cams are the brains behind the beast....doesn't matter what the heads flow. Valves still need to open for long enough periods of times to accomadate cubes...
