TSP's New 233/239 .603/.600 Camshaft ! ! !
Old 12-19-2004, 04:36 AM
  #81
PREDATOR-Z's Avatar
It is listed in the cam section at bottom of page.
Old 12-19-2004, 07:02 AM
  #82
a98ws6's Avatar
Originally Posted by Jason 98 TA
The camshaft has right under .100 clearance on each side! That being said .030 would make it tight, but it probably would work. Joseph is going to install it on heads cut 30 & 918s & test it next week
Would your Torquer or 233/233 fit with .030 milled heads? I would think if this cam might fit, the other two would? Also why go with the 918's? Isnt this cutting it close with the lift?
Old 12-19-2004, 08:33 AM
  #83
PREDATOR-Z's Avatar
With proper valve geometry, 918's are good till .625 lifts.
I run them on my XER .581 lobes no problem yet.
Old 12-19-2004, 09:00 AM
  #84
AINT SKEERED's Avatar
I have 918's on my fm 13 cam and so far so good. No valve float all teh way till 6800 yet
Old 12-19-2004, 09:13 AM
  #85
CamaroCain's Avatar
I want to see how this cam would do on the track w/4000+ stall converter, maybe some 3.73 gears on a good sticky tire.
Gotta love those guys at TSP always coming out with new better stuff, making the competition dropping their jaws trying to catch up
Old 12-19-2004, 10:50 AM
  #86
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Thanks for all the support everyone!! Sorry for being so slow replying! This camshaft has better p/v than a torquer cam does. That being said if I was to try a cam with heads cut .030 it would be the 233/239. If heads have been decked you always want to check p/v!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-19-2004, 12:08 PM
  #87
PREDATOR-Z's Avatar
Jason, what would be the recommended minimum stall with that cam??
Old 12-19-2004, 01:48 PM
  #88
USMC Devil Dog's Avatar
Jason,
Would this cam work with 6.0L/LS6 59CC Patriots? If so, what valve size and valvetrain would you recommend? On a 02 6 speed what rear gears and clutch would you recommend?
On a side note, why has TSP stopped selling Patriots? I have sent TSP (I believe it was mailed to you) some questions last week about this cam and have not received a reply (My email address is Rotc292648@aol.com). I understand that you guys are probably over your heads in work being the holiday season and all but I would like to get my order in before Christmas. Can't beat $310!
Semper Fi!
Old 12-19-2004, 03:10 PM
  #89
Checkmate's Avatar
Jason, I sent you PM.
Old 12-19-2004, 03:52 PM
  #90
a98ws6's Avatar
How would I check the P/V? I really like the new cams TSP has came out with!
Old 12-20-2004, 11:18 AM
  #91
BADSZ28's Avatar
As far as I know you have to pull a head, put some clay on a piston, reinstal the head, rotate the engine 2 full revolutions at least, pull the head and measure the thinest valve impression in the clay in relation it the piston.
Old 12-20-2004, 11:26 AM
  #92
PREDATOR-Z's Avatar
Claying is quite innacurate, the only true way to do it is using a dial indicator.
You'll need:
1- Dial indicator kit
2- lightweight springs
3- modified hydraulic lifter
3- The knowledge to do it (LOL)
Old 12-20-2004, 11:37 AM
  #93
BADSZ28's Avatar
Either way, a pain in the ***. lol.
Old 12-20-2004, 02:24 PM
  #94
Black SS's Avatar
Anyone have a phone#? Website not working
Old 12-20-2004, 05:57 PM
  #95
69_YENKO's Avatar
TSP phone #806-866-0734
Old 12-20-2004, 06:11 PM
  #96
Sorry for the delay guys! Clay is a very bad idea! Follow the test spring way.
The camshaft made 393rwhp in a unlocked 3500 stock head car yesterday!! I'll try to post the graph asap!
I think I replied to all the IM's guys! Sorry for the delay!
__________________
Jason
2005 Twin Turbo C6
Old 12-20-2004, 10:59 PM
  #97
Hey Jason can you help answer mine? Its eight posts up! ^
Old 12-21-2004, 09:56 AM
  #98
a98ws6's Avatar
Can we get the sound clip back up??
Old 12-21-2004, 11:41 AM
  #99
Cobraeater's Avatar
Talking
SupahRich is hosting the same video clip on his site that's two posts down from Master Chief's clip.
www.supahrich.com/MOV00397.MPG
Old 12-21-2004, 04:29 PM
  #100
gnx7's Avatar
what exhaust system is that? It is crazy loud. Is it duals or single?
That is the cam I ordered... Hope I can make mine quieter....
-GNX7
Quick Reply: TSP's New 233/239 .603/.600 Camshaft ! ! !
