Crane 1.8s, can you run them with solid roller to adjust valve lash?
Re: Crane 1.8s, can you run them with solid roller to adjust valve lash?
You need adjustable rockers like jessels or T&D. Shimming is a BITCH.
It is possible, but a pain. A local guy down here runs them on his solid roller all bore motor.
they do have guide plates and if by poly locks you mean the little hex nut on the locking nut , yes they came with those
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ:
<strong> they do have guide plates and if by poly locks you mean the little hex nut on the locking nut , yes they came with those </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I thought so, basically it is just like a regular sbc rocker then and would be fully adjustable - too bad they are 1.8 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GrannySShifting:
<strong> From looking at them they look like SBC stuff, so Im wondering why peoepl say you cant use them to do it with? They arent stud mounted??? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually they are stud mounted, thats why you need the guideplates - they cant be 'shimmed' like stock rockers. You could use them with a solid roller since they are adjustable but you would probably have to get a cam custom ground to use with the 1.8s. I would imagine most solid rollers ground for 1.7s would be too aggressive to use with 1.8 rockers. For what the cranes cost you are almost to a set of t&d or jesels moneywise anyhow. Unless you already had the cranes and just get a cam made...
<strong> Ok so if they are stud mounted, and the lash is adjustable, why cant you use them wiht a solid roller? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I didnt say you cant, everyone else did <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I see no reason why you cant use them with a solid roller..
