For those with Scoggin Dickey Timing Sets
Old Apr 16, 2003 | 04:42 PM
ChiTownSS's Avatar
Default For those with Scoggin Dickey Timing Sets
How many degrees retard/advance can you put in a cam with the SDPC timing set? I would rather go with the more heavier duty of them and get the double roller.
Also, would I have to get an ASP pully machined to fit this type of timing chain?
Old Apr 16, 2003 | 05:37 PM
LS1derfull's Avatar
Default Re: For those with Scoggin Dickey Timing Sets
You can go 8* advanced and or 8* retarded. I run hardened Rollmaster that i got from SDPC with oil pump spacers. Real nice piece, and i dont reccomend you advance any cam for lS1, straight up or slightly retarded with average popular size cams. I dont know about pulley clearance but i heard only vettes have a problem with this?
Old Apr 16, 2003 | 06:01 PM
Tim 98z's Avatar
Instaled the Rolmaster (SDPC) double roller with ASP pully two week ago. No problems here.
Old Apr 16, 2003 | 06:07 PM
Tin Indian's Avatar
For any of you thinking about getting the Rollmaster single timing set; It's of high quality, but [IS NOT] adjustable. Oh well, even if I had bought an adjustable set, I would have more that likely just stuck it in there dot-to-dot anyway.
Just thought I would let you know about the single chain set.
Ron,
Old Apr 16, 2003 | 06:30 PM
ChiTownSS's Avatar
LS1derfull, why do you say not to advance a cam in a LS1? My cam is a 226/224 112 lobe and it has ZERO advance. I was thinking of advancing it about 4 degrees so I don't have to shift any higher than 6,500 rpms.
Anyone have the link to the SDPC double roller?
Tim 98z - Any tips on the install of the two pieces? So, no machining of the ASP pulley?
Thanks guys.
Old Apr 16, 2003 | 09:34 PM
ChiTownSS's Avatar
TTT
Old Apr 17, 2003 | 02:11 PM
ChiTownSS's Avatar
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 17, 2003 | 06:24 PM
Redlinez's Avatar
I'm getting my cam with a +4 degree advance ground in. For a street driver, I'd rather gain some bottom end. I'd do the same on yours.
Old Apr 18, 2003 | 01:48 AM
DreamWeaver's Avatar
I believe that any double roller requires spacers placed on the oil pump. This caused pump to ballancer sleeve clearence issues for ma and several others have also reported this. There is a active thread on using a ASP pully with a double roller timing set - explaining what needs milled - check it out
