questions about ls2 timing chain.....
Old Dec 21, 2004 | 12:03 PM
Raise's Avatar
Default questions about ls2 timing chain.....
when i do my h/c swap, im gonna replace my chain with the ls2 chain. my question is....will i only need the chain?? is there anything else i need to buy with it in order for it to fit my car??
Old Dec 21, 2004 | 01:07 PM
black_knight's Avatar
I would also like to know this.
Old Dec 21, 2004 | 01:18 PM
SideStep's Avatar
I used one on my H/C install. Works great and it is bigger/beefier. All you need is the chain....
Old Dec 21, 2004 | 01:48 PM
KJ's Avatar
KJ
I have talked to alot of people on this, and you should be ok with just buying the chain. The chain I have in stock for $28.25, or if you wanted the cam gear, crank gear, and chain we can do that for $71.61. We also have the Rollmaster timming sets in stock. I can get you into a single row for $59.80, and a double row for $114.00. Let me know if I can help!!
Old Dec 21, 2004 | 02:48 PM
Thanks you; I have done business with you before and it looks like I will be doing so again in the future!
Old Dec 21, 2004 | 05:12 PM
PewterC5-2000's Avatar
Used the LS2 chain several weeks ago during my H/C swap. Working fine for me....
Old Feb 7, 2005 | 09:04 PM
SDB's Avatar
SDB
What about the LS2 dampner that can be run with the chain??? How much does that run? Will te LS2 timing chain, crank gear, cam gear, and dampner work with a 2000 F-body with ASP pulley?????//
Old Feb 8, 2005 | 11:19 AM
Raise's Avatar
thanks for the chain kris.........u da man
Old Feb 10, 2005 | 04:15 AM
ZR2877's Avatar
kris I'll be giving you a call later today. That's a great price.
Old Feb 10, 2005 | 05:51 AM
See5's Avatar
This is my LS2 chain and tensioner:
