ASA cam in a stock LS1 ?
or is there a different cam I should look into ?
Thanks
That said, there many cams on the market that will kick the crap out of the ASA cam in terms of performance and driveability.
The hottest out there right now are the FM13, TSP233/233, TSP233/239 (on the mildly large side), the TRex, the TSP MS3, the MTI Y1 (on the very large side).
The TR224 is the benchmark cam. A TR224 will perform as well if not better than the ASA on stock heads.
(in case you're not aware)
TSP= Texas Speed & Performance
TR= Thunder Racing
MTI
FM= Futral
----------------------------------------------------> click the banners
hope this helps.
What gear do you run out back?
PS: The ASA + GMPP CNC LS6 heads would be the H/C combo I would elect if I were to do everything over again (never change springs again)........
it always performs best that way(matched up). The Best V8 Stories One Small Block at Time
1) Open up the throttle body butterfly w/ the screw about 1 turn. Theres link on this site just how to do it correctly. Although there seems to be a fine line if the throttle is opened too much it seems to set the "TCS" light and you get a throttle position code error. I think it's P0120.
2) Eliminating EGR w/ HP tuners. This was a big help as I was getting too much exhaust during idle and part throttle cruise. I just have to remove the EGR system this weekend.
3) Pacesetter LT's w/ TSP catted Y pipe. Really big inprovement that got my lowend torque back. Now the car pulls HARD from 2000rpm on up. There's a link if you do a google search under "ASA cam" that is from GM on how the ASA cam needs to breathe. Putting the ASA cam w/ stock exhaust in a Vette only gained 2hp whereas using a low backpressure exhaust system gained 20hp.
I have some more tweaking to do as my LTFT's on the passenger side are rich @ idle and I get some light surging between 1200-1800 rpms. I might have an exhaust leak, bad O2 wire (spliced and soldered extensions).
I haven't dyno'd it yet but I like it. I had put LT4 hot cam, heads, intake on my old '97 WS6 T/A and this setup is definately better. The idle is totally mean too.
Jeff
'99 WS6 M6 Formula
ASA cam, LS6 springs, Pacesetter LT's, TSP catted Y-pipe.
