XE 224 Cam
Now I have been reading lately and have noticed that XE lobes are one of the slowest ramp rates and make less power, idle worse and have worse throttle response. I did not know about this before I got my cam and was wondering how much power difference their would be between my cam and a tr224 or a 224 .581 comp with XE-R.
This has my kind of upset thinking my car will be a dog...
But one plus is that it will be eaiser on the springs correct?
They are good for .600 lift and I have titanium retainers...so with only .563 and the softer ramp rate...I wont have to worry about them for a while...correct?
It doesn't mean you'll change them, but that will let you know how the valvetrain is holding up.
As far as driveability and idle, you'll need a good tune, then you'll be the judge
Even if everything you say is true about XE vs XER, it certainly isn't worth opening up the engine for that change. Maybe next time your ready to jump back into the insides, you can make another cam choice. Enjoy your cam and drive the heck out of it.
Take your cam card and find the .006 adv lift and the .050 lift. substract the 2 and you'll find it is 51.
XE is 53 and XE-R is 49 so yeap the lobes are right in between.
Basically with the effect of XE-R but a little more mercifull on the valvetrain.
And yes..I love the way it ran before the cam...I was right in the mix with an 03 cobra before the cam...I am going to have a little extra for him this summer when im done, being I will be about a half second faster than I was before when im done with everything... "your car sounds different"... ME... " Its just my true duals!"...lol
Here is basically everything on the cam card
First of all the grind # is ls1 3715r /3715r hr112...no advance ground in
Gross lift .563 .563
duration at .006 tappet lift 277 277
Duration at .050 intake 224 exhaust 224
Lobe lift .3310 .3310
Lobe separation 112.0
Well the advertised duration at .006 is 277 and .050 is 224...so it comes out as a 53...damn
So whats the deal here...custom xe grind? Also...it has no advance ground in...should I worry about this...whats the deal with that? do I have to degree it?
I got the 224/224 .563 .563 114 cam from ls1speed 2 years ago. Loved it ever since...
as far as power? Dunno, but mines run pretty well with it and dynoed pretty good for the setup on tea 1.5 heads.
You are just worried you made the wrong choice now.. stop thinking about all the info you are reading
Just be happy with whatcha got now loli still have my 224 and will probably have it for a long time lol
I knew it was the older cam from ls1speed, it even says that is where it is from on the box. So it probably isnt a custom grind...just they dont make it anymore.
What did you put down before your heads with that cam? And I am assuming you had full bolt-ons and exhaust? Whatever you got I will add around 10 hp becuase I have a manual and use it as a baseline.
But yes comp did make that cam with 563 lift. I guess they dont grind that anymore but I know it was a option about 2 years ago from ls1speed that comp did.
I dont have any cam only numbers, but it shoulda been in the 370range for mine. Another friend in his A4 dynoed 375 with his TR224 and he went 11.6@116 or so, so the ET's were pretty dead on and we had almost the exact same mods down to the stall. 2 other guys pulled 390's with the 224's in there 02 cars cam only. You should definitly be 380's or better cam only with that cam and a good tune
Sucks that us autos need heads to dyno what ya'll do cam only lol. BTW, dont worry to much about dyno numbers. Dynos seem to vary.. as long as you dail in your A/F your car should scream with that cam
