Cam for A4 w/ no stall?
To me the cam is to much headache and a stall owuld be the simplier choice to go with. When adding the cam, you gonna tune the car to perfection to see the best gains. Idle could be crappy or it could be perfect. Cam swaps are hit or miss.. some love.. some wanna sell the cars 3months afterwards cause of the headaches.
most that get converters are smiling 24/7
By you post, im guessing you already know you should get a converter. Yes people have done just cams and no stalls... most jsut do that for the sound. Im sure the car will fly from like 45mph with a cam and n20 though. Anything below 45 and its gonna be dead and you gotta play catch up
good luck
whispers in a silent voice "get a friggin stall first LMAO" hehehehhee
Get a converter first!!!! BTW: If you don't feel like messing with the tranny why do you have no problem messing with the engine? If you don't want to mess with it yourself have a pro shop do it. I installed everything in my sig except for the converter and shift kit because I didn't want to screw with the tranny myself either.
My best 1/8 ET improved slightly from hi 8.2s to an 8.200, but my 1/8 mph jumped to hi 88s low 89s from ~86. In the 1/4, I only gained 0.1 ET/1 mph. So the mph gains in the 1/8 didn't carry fully over into the 1/4.
Driveability improved with the small cam. Snappy part-throttle response, blah, blah, blah... The 3-2 downshift "dead spot" is NOT cured by the cam, but it did help it a bit.
If you are out to primarily improve your track numbers, steer clear from going this route. Do the converter first as mentioned above. I hope you gain some insight from my experience.
Pacesetter LTs
custom 3" Y with high flow cats
slp lid
ported & polished TB
!air & !egr
flowmaster muffler
Predator
CC cam and retainers
NGK TR55 plugs
my car sees the track 1-2 times a year and i am not trying to build a full out race car.
so, how big of a deal is it if you go with a cam and no TC.
i need to do some searches on the boards,
Good luck and when you do a cam, even though I'm happy as hell with my TR220/220 on a 112 LSA, I'd probably would do a TR224/224 on a 114 if I had it to do over again .... love the 112, however, too much LSA for my upcoming Supercharger.
