CNC Inc. heads
Old Jan 11, 2005 | 10:00 PM
993rs's Avatar
Default CNC Inc. heads
Anyone hear running CNC Inc. heads? They are out of Florida, a local shop
really likes them.
Old Jan 12, 2005 | 06:49 AM
Mike Norris's Avatar
We use them at our shop quite a bit for the past 5 years or so and have very good results.
A 383 making 490-ish RWHP. 427 at 500+RWHP, basic LS1 heads/cam packages at 425RWHP with a 224/224 XE, Z06 with a basic heads/cam at 445RWHP with a 226/230 XER and so on.
A lot of folks will say that these are average numbers and that is my point. In a similar combination, the CNC heads will run with the best of them. Flow numbers and port volumes in the range of the AFR's for the most part.
They do not "pretty" them up as some shops do, so you will get the "does not look as good as the X brand head", but they do what is needed and it works. Of course there will be several opinion on this to say the least. Hope this helps.
Mike Norris
Old Jan 12, 2005 | 09:32 AM
RX-Ben's Avatar
FWIW- I called the shop once and they are very knowledgeable and helpful and are a big, well funded shop (helps with R&D). I wouldn't hesitate to buy heads from them.
Ben
Old Jan 12, 2005 | 11:40 AM
993rs's Avatar
Thanks. I was told that they have AFR performance without the AFR price premium.
Old Jan 12, 2005 | 12:37 PM
JZ'sTA's Avatar
I have seen quite a few different setup's using these heads, and have never been disapointed with the results.
Old Jan 12, 2005 | 06:19 PM
texada's Avatar
Any of you guys have their phone number?? If so, I want it!
Old Jan 12, 2005 | 07:09 PM
DBN's Avatar
DBN
I have been running CNC LS6 heads for about 2 years and I am very pleased with the results. In my 2000 C5 346 A4 I ran 11.07@123.87.
Old Jan 12, 2005 | 11:39 PM
texada's Avatar
Thanks!!! I will be in the market for some heads here real soon. What gear and head and cam package do you have in your C5?
Old Jan 13, 2005 | 12:02 AM
JS's Avatar
JS
Florida CNC/Pete are great guys,U wont go wrong with his parts
Old Jan 13, 2005 | 06:46 AM
We are a warehouse distributor for them if you need any info or need to order anything. Pete @ CNC is also very helpful at the number posted above. Hope this helps.
Mike Norris
Old Jan 14, 2005 | 07:42 AM
firehawk933's Avatar
I have their Heads with the set up in my Sig. very happy with them
Old Jan 14, 2005 | 08:42 AM
Noyzee's Avatar
8 second mod
I have a set of CNC ls6 heads, there cnc/porting job was great, the valve job was only so so. i had a local shop redo the valve job, and no more sealing issues.
overall im happy.
Old Jan 14, 2005 | 11:27 AM
Jay 95WS6's Avatar
pete@ CNC is a stand up class guy with a wealth of knowledge that won't steer you wrong
Jay Fisher
