what is the stock size of a set of 5.3 heads unshaved
what cc are they stock? needing to know for when i change pistons and i am going to have them shaved alil aswell. thanks
For the search button challenged
A few posts down.
https://ls1tech.com/forums/advanced-engineering-tech/111207-ls1-head-combustion-chamber-cc-volume-vs-cr.html
A few posts down.
sorry mr atl as you can see when i started and how many post i have now that i do not get on here much, dont really need much info, know most of it just was wanting a quick answer while i checked my stocks damn. but thanks anyways
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by 02Reaper
What about when you open the chamber up to a 3.90 bore, for all of the ********* who say use the search button? 61cc is for a 3.78" bore. I am sure it would be different.
thanks fellas i guess you guys cought the same drift i did. a wana be smart *** had to say use the search button cause he seen someone else say it. and his link had so much chitter chatter around my question I lmao, but thanks for both real replies. and to the guys who know what they are talking about, agian thanks
Quote:
"thanks fellas i guess you guys cought the same drift i did. a wana be smart *** had to say use the search button cause he seen someone else say it. and his link had so much chitter chatter around my question I lmao, but thanks for both real replies. and to the guys who know what they are talking about, agian thanks"
No, I get tired of reading the same posts over and over again. I'm not trying to be rude, just trying to spread technical knowledge. Personally I use the search feature and find it very useful, that's all I'm trying to say. That link has all the techinal info on heads and cc's that you will ever find. Maybe you should read the whole thing.
i did read and found that two guys said two diffrent things on the 5.3 heads , so ill just wait till they come here and i'll cc them myself, sorry for the bother and that i made you come in and reply. if you dont wana reread it then dont come in, leave it to the guys who like to share there knowledge and not someone who it gripes there *** that someone who gets on here say once a month or so and asked a question about something you already knew or read about. like i said sorry for the bother, and hope you dont make the same mistake i have and ask something someone else did thanks....
