Lingenfelter GT2-3 LS1 Camshaft and Valve Spring Kit
#41
SN95 Director
Originally Posted by Ed Potter @ LPE
207/220 @ .050
Flareside, we've used this combo wit LS1, LS6 and aftermarket 2.02/1.57 valves and not seen any issues with valve float, you are correct that the shorter LS1 valve decreases the amount of lift the springs can handle, but it's not an issue in this combination.
This is a tried and true setup we've used fopr several years. Car Craft magazine did a dyno test with this same setup on a 5.3 with very similar results.
Ed
Ed
i know alot of people who look for sleeper cams but are scared of the gt2-3 because they see the high lift and think its agressive.
#42
207/220 @ .050
Ed
Ed
"This is a tried and true setup we've used fopr several years."
LPE knows their ****. End of story. If Ed says it's gonna work then I trust him.
#43
Closed ex-Sponsor Account
Thanks for having faith in me!
To answer jrp's question, duration at .006" tappet lift is 255/281
I'll even go as far as to say if anybody buys this cam, and feels that it's too aggressive, I'll buy it back myself!!!!!!!!!!!! This is a super mild cam, and if a sleeper cam is what you want, this is the cam for you.
Hope this helps,
Ed
Hope this helps,
Ed
#44
Hope this helps,
Ed
Hope this helps,
Ed
Switching to this cam and a Texas Rear Turbo kit with that one piped exhaust thing. LOL It'll be so much quieter and calmer. Which Will be much more sleeper suprise.. hehe. But most people know about my car anyway so w/e
ED I primarily have faith in LPE and what you learn not you per say. hehe just kiddin.
#45
11 & 7 Second Clubs
Wow, this topic should have been resolved in 4 or 5 posts! Does the selection of a mild cam for a street car really deserve 44 posts? D3IMOS, Ed and i gave you the answer on the first page of this thread.
#46
#47
Originally Posted by D3IMOS
Dude. relax a lil . LOL. There was a lot of informative stuff on here.
Ed, thanks for the info. I have a set of your GM/LPE CNC heads here with those springs, and they have a tag on them that says .570 max lift, so I'd guess this cam is near the limit of what they'll tolerate. I'm actually going to run this cam with AFR heads.
#48
Ed there has been some very deatiled discussions on these hot cams.
https://ls1tech.com/forums//showthre...0&goto=newpost
#49
Originally Posted by 11 Bravo
That thread is about a regular GM Hotcam. You've said before that your LS6 GENIII HOTCAM is better than the hotcam, but has been discontinued? What are the specs on this discontinued cam?
#50
Hope this helps,
Ed
Hope this helps,
Ed
#51
Sorry for to bring up an old thread.
Questions for Ed Potter,
I need to know the difference in the 2 LPE cams
GT2-3 V's GT7
How does the GT7 idle compared to the GT-2 ? (that is like a stock cam)
What power does the GT7 make ?
cheers
GT2-3 V's GT7
cheers
