How are you guys pulling the motors?
not sure if this would go here or not, but since its the engine section i figure ya'll would know.
I have the cherry picker and motor stands.. the heads are off the car so we were iffy about hooking a chain to the head bolts since those have a little to much play in them with no heads on the car.
We tried hooking to the ground bolt holes on both sides of the block, but the chain seemed like it may gash the bottom end.
so how are ya'll going about removing the bottom ends through the top of the car?
are you using that plate that bolts to the valley cover?
we were gonna take it out from the top since we didnt have enough time to drop the K member that night. We might just go ahead and drop the k member monday if we have enough time.
do you have to take out the trans to drop it from the bottom or or top?
Originally Posted by kickassT/A
out the bottom. take about 2hrs to drop engine and transmission
I have done this, well I can't count that many times, but I can have the motor out and off the K-member on to the engine stand in a 45min-1hr. I guess it is easy after you do it so many times. This is the easiest way by far. It is almost easier to take the motor out as it is to do anything else.
i pulled the motor with the a4 tranny attatched to it out the top with the heads on..pulled all accessories off front of motor..pulled off intake..i attatched my chains to the head bolts..one in the front driver side head..i believe where the pwr steering brkt bolted..the other on the spare hole on the passanger side head on the back side..have to get the motor at a crazy anlge to get it out..i think i only had like 4 or 5 links in the chain in front and about 3 times that in the back..motor has to be almost straight up and down due to trying to get the tailshaft out to clear... not too bad..
matt
matt
red, thats the thing though. We dont have the heads on the car. Those head bolts just had a little to much bending/play in them. We didnt wanna strip threads anywhere lol..
Ive got a friend thats gonna make a plate tomrrow for me to attach to the valley cover. So hopefully we can get this pos outta the car monday. Everythings unhooked, just need to lift it up.
Worse come to worse, the k member come sout since the pa racing one is on order already
If you have the room to do it, take it out from the bottom.
I pulled mine from the top w/o the trans - PITA ~ 10 hours (first time). I put it back in from the top with the trans - Much easier ~ 2 hours
If you are dead set on going from the top, it helps to remove the right motor mount pedestal.
The bolts will hold the weight of the motor and tranny with ease. I pulled my iron motor with a PG out from the top before and used the head bolts to attach the chain to the cherry picker.
From the bottom on a lift with 2 people takes ~2hrs. I wouldn't do it any other way. So much easier. The only potential downfall from going out the bottom is that you will need an alignment. If you are doing some front suspension work at the same time you would need it done anyway.
Mine is pretty easy to pull because my car is stripped, but it came out the top pretty easy the first time with the trans still in the car, just put something under the trans to hold it up while the motor is out.
Also, I unhooked my hood supports so I could put the hood straight up, and that helped me get it out.
Good luck!
well we took it outta the top tonight.. came out like a breeze...
had a friend make a plate to bolt to the valley cover today and that worked perfect!
http://www.slowls1.com/mplate2.jpg
http://www.slowls1.com/botend3.jpg
