what is the biggest cam u can run with a 5.3 liter head
You can run the same 'big cam' with the 5.3l heads as you can with the 5.7l heads. There isnt a specific 'biggest cam' since there are so many factors that go into deciding if a cam fits or not.
I doubt it would go up at all using a stock 5.3 head in fact I bet it would go down. Now comparring ported to ported from what we have seen a ported 5.3 head seems to be worth about 20-30 hp over a ported 5.7 head
Since it's impossible to determine with all the possible grind combinations, How about some options in big "shelf cams" like the G5X3 or the MS3.My valves are 2.02 and 1.6 on unmilled 5.3 PP heads. I want a max effort cam to work with my heads and n2o. Any suggestions??
