Flow numbers for GM Perfrmance parts LS6 CNC heads????
#68
It is not that easy, Mike @ High Flow runs a business and Jason has told him he doesn't want to pay for the flow, I said I would as did you. Every time either I or Mike (once per person) tells Jason when it can be done he says he will call us back and never does. Mike does a lot of heads for NMRA and other serious racers, to have him drop everything at the drop of a hat for free or $50 to flow a set of heads is a lot to ask wouldn't you say? Lets set up an opointment and stick to it, other wise take the heads somewhere else that hasn't flowed top heads from Patriot and TEA.
#69
Originally Posted by Ed Potter @ LPE
If you want to upgrade to the 2.100 valves, the best thing to do is buy the heads straight from scoggin-dickey and send them back to us for big valves, bigger seats, new valve job, and I would get the full hand sanding for maximum flow. We would charge 950.00 for all of the extra work. This would still give you a full boogie set of heads for less than 3,000.00
Hope this helps,
Ed
The AFR is the better buy. Sorry!
#70
Originally Posted by gollum
The less expensive, thicker deck, AFR 225 heads have all of the above mods with new valves and springs installed.
#71
Originally Posted by ONEBADWS6
Jason when are you free to do the test? You never called Mike back Sat, are we still going to do this?
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#72
That is fine with me, when I talked to him he was under the impression you were going to call him on Sat, just a misunderstanding. He said he will only charge $50 to do the testing. Let me know what you set up with him.
#79
6 Second Club Moderator
ARE Stage 3 LS6 heads complete THese ARE 243 Castings, not the fake wannabe LS6 heads....
Less than 500 miles on them
Decked .045
Heads come with titanium locks and retainers
Have 1.55 Dual Springs
Stainless valves(2.100,1.60 exhaust)
Flow the following
Lift Intake Exhaust
100 74 66
200 135 127
300 204 148
400 260 199
500 293 222
550 306 228
600 321 231
650 328 232
Chamber CC's are 61.5 CC's
See what I mean
Decked .045
Flow the following
Lift Intake Exhaust
100 74 66
200 135 127
300 204 148
400 260 199
500 293 222
550 306 228
600 321 231
650 328 232
See what I mean
