What special tools do i need to install a cam??
Old Feb 4, 2005 | 01:44 PM
RGV_Z28's Avatar
Default What special tools do i need to install a cam??
Do i need anything special to install a cam??
Old Feb 4, 2005 | 02:34 PM
BLASTER's Avatar
-Crank holding Tool A.K.A screwdriver(if A4)
-Pulley Puller
-Lifter holding tools (two 5/16 rods or 16 pen magnets)
-Pulley Install Tool
-Spring Tool
Old Feb 4, 2005 | 02:38 PM
mattrem's Avatar
A 3 arm puller to remove the crank pulley and 16 pen magnets to hold the lifters. It is pretty easy to do. And a longer crank bolt or a piece of threaded rod to get the pulley back on the crank. And I used the Matco LS1 pulley holding tool, worked pretty dam good to get the new bolt stretched.
Old Feb 4, 2005 | 02:40 PM
Turo's Avatar
nothing special, but it really really helps: 10mm gear wrench
Old Feb 4, 2005 | 04:54 PM
Mark98SS's Avatar
A lot of cams require new valve springs. For that you need a suitable valve spring compressor & air compresssor/spark plug air fitting to keep the valves closed while changing the springs.The Moore Valvespring compressor works real well, especially on the rear cylinders (the ones under the windshield).
Old Feb 4, 2005 | 04:59 PM
BLASTER's Avatar
All aftermarket cams require aftermarket valvesprings. You can use TDC method to do the springs and don't need the compressor. Much easier. Too bad I bought the compressor already
Old Feb 4, 2005 | 08:31 PM
Black Z's Avatar
Old Feb 4, 2005 | 09:00 PM
Black Z/28's Avatar
Crane tool for spring replacement- awesome! (if you can handle the price).
Old Feb 4, 2005 | 10:15 PM
01_SuperSlow's Avatar
I'll second that, worth every penny.
Old Feb 4, 2005 | 11:31 PM
code4's Avatar
Something to hold the lifters up (I use 5/16 rods) Pulley puller, valve spring compressor (search "larry tool") & basic tools. To be extra safe you can use one of these allthread bolts to reinstall your pulley.
Old Feb 5, 2005 | 05:32 AM
Phil'sC5vette's Avatar
I used my credit card and the installation was easy
Old Feb 5, 2005 | 11:28 PM
TheMNkid's Avatar
Lol... Good one!
Old Feb 5, 2005 | 11:44 PM
Zangel's Avatar
Fiery Features Director
Fuel line disconnect tool. Would definately make life alot easier
