Need help CAM GURUS please help
Old Feb 11, 2005 | 04:12 PM
coop5885's Avatar
Default Need help CAM GURUS please help
I have an MTI Z1 (236/236 .585 .585 112). I called MTI once a few weeks ago and they said that i would have no problems with this cam in a stock cubic inch motor as long as the heads were not milled. So i called them back today to double check before i put the cam in, and i was told that there would definatly be p/v clearence issues.
SO WHICH IS IT???
i figured that since i cant get one answer from MTI i would ask you guys.
Someone please help me out here!!!!
(so far im not impressed with MTI)
Old Feb 11, 2005 | 04:31 PM
Unaffliated Racing's Avatar
Well, that is the thing with piston to valve clearence. Nobody can tell yoou wether or not it will clear. There are too many variables in the motor that will determine that. You ALWAYS need to check piston to valve clearence yourself. The main thing with this cam clearing is where it is installed at. If you put it in straight up or retarded a little bit you probably won't have a problem. Thing is nobody wants to say "hey yeah it will clear" and them be wrong..espically if you don't check it and fire the motor and bend all the valves or maybe worse.
Old Feb 11, 2005 | 04:35 PM
coop5885's Avatar
so what your saying is as long as i install it dot to dot then i should be ok? now if i even put it in im going to clay it to double check, but im trying to make sure its worth my time to put it in and check.
Old Feb 11, 2005 | 04:39 PM
If there is a serial number on the back...give it to me.
Old Feb 11, 2005 | 04:48 PM
coop5885's Avatar
it has 222306 ground into it. then etched into it it says 3705R/3705R
LS1 HR 112
Z7141
Old Feb 11, 2005 | 04:59 PM
WS-Sick's Avatar
I don't see why there would be any problems with that cam on unmilled heads.
Old Feb 11, 2005 | 05:01 PM
Its a .578" lift cam and it has four degrees of advance ground in. If you have any clearence problems...retard the cam some.
coop5885's Avatar
awsome.....thank you so much. You guys are life savers
