Cam only cars in here
If you are getting a bigger stall, then something in the 224-230 range
ifffffffffffff you drive the car daily, then i would stick with a 224/224 or 226ish cam maybe all on 114
if you dont drive the car a whole lot, then check out some of 228-230ish cams. Futural makes some good grinds. There F10(228/228) seems to be a nice cam. Im sure some will jump in and say they have cams bigger that idle great. Well, thats good for them. But the idle and other isues with a bigger cam may get to and annoy some of the daily driven car owners
anything in the 224-228 is a nice, daily driven cam choice. Of coarse the smaller you go, the less hassle you "may" have with idle. A4's are hit and miss.. some idle fine, some dont. Tuning will fix that, but wont make it picture perfect. Get the stall first, then if you want get a cam.. but a bigger stall will make you happier than a lil cam:-P
get a 3600-4000 stall and I think that will hold you over for a while... then get a cam later on if you still feel the need. Its a whole lot of less headaches with a stall then going internal:-P
F13 is a 230/232 cam
i just got a F11 228/230 cam since my car see's more street than track now.
goodluck
