Worried about o-ring, need advice...
My oil pressure is 35 psi with the car at hot idle, and doesn't get over 60, even at 6k rpm @ WOT. What are the correct pressures? Is it safe to drive my car daily, or do I need to tear down the front end this weekend and replace it?
Thanks in advance,
Allen
Engine water temp: 200* F
Idle in drive or park: 30 psi
Normal driving: between 35 -45 psi
WOT @ 6,000 rpm in 2nd gear: 58 psi
This can't be healthy. The ticking noise is louder now at idle than it used to be ( a month or so ago ). It definitely seems to be directly related to oil pressure.
The oil is Mobil 1 10w30 and I'm running an AC Delco PF 59 filter.
Has ANYONE heard of or run into this type of thing before? I don't think that there's a blockage, because the oil pressure rises pretty quick, it just doesn't rise a whole lot.
Maybe I'll poke around and see if I can't find some of that German Castrol here.
Can you elaborate on this turned lifter?
On a side note, I think that it's a lifter because I read something about being able to get rid of lifter noise by holding the rpms at about 2500 or so for five minutes. I did that and it was gone until the next time the lifters had a chance to bleed down.
I'm wondering if changing from the PF46 to the PF59 has anything to do with the lowered pressure. I remember something about a different bypass setup with that filter. Anyone have any idea? It didn't do it until after the filter change.
I'm feeling very relieved.
