G5X-2 cam & head Dyno Numbers
We have one very good drag racer in our customer base. The car went 11.06 @ 122, 1.47 60 ft with the G5. I suspect that that car will be in the 10's with just the cam swap, since they have the other good sutff for drag racing now.
That will be the car that we will do first for the 1/4 mile.
Plus we are finishing up the "Drag" car, Fbody that will run in the shootouts. This car will be ready for spring time shootouts with our new and improved shoot out design ready to do battle. There are not enough hours in the day, or days in a week.
Thanks,
Lou Gigliotti LGM
<strong>
10.7-8:1 CR
Pumpgas that was a week old
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks!!! This answers my compression question <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong> I have a stupid question, which all the talk of other's copying someones cam specs, etc, who are some of these copiers? I'm just curious. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Here is one. Pick up the latest edition of GMHTP. There is an advertisement for Lunati. Add reads "Internal Engine NEW! LS1 Cam"
221/221 .558/.558 on 114 Sound familliar?
Any Guesses?
MTI "B1"
<strong> I have a stupid question, which all the talk of other's copying someones cam specs, etc, who are some of these copiers? I'm just curious. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">C-1 comes to mind <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NastyC5:
<strong> I have a stupid question, which all the talk of other's copying someones cam specs, etc, who are some of these copiers? I'm just curious. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">C-1 comes to mind <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Lol like The Andy Cam? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong>
Most folks on this board have seen lots of cams, and aren't gonna shell out $400+ for cam they don't get specs on. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> $400+ <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
I called LG Motorsports about a G5 back when the G5 spec's were a big secret I was told the price of the cam and install kit was like $950
The TSP 224/ MTI C2 -Identical
AMS supposedly had/has a 226/226 .591/.591- GTP Pig cam comes to mind
And the T1+3? the Thunder 224/224 561/561
<strong>
And the T1+3? the Thunder 224/224 561/561 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How could you even remotely come up with the TR224 is a T1 with 3 degrees more duration? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> There is a lot more to cams then just the advertised numbers. Look at the lobe profile of the T1 compared to the TR224 and you'll see that they are not even close to each other. The TR224 has a much more aggressive ramp rate and a lot more area under the curve. The TR224 as well as the 220, 227, and 230 lobes are owned by Thunder Racing and are totally custom. That is why we can publicly post the cam specs without fear of someone copying them, unlike some companies that pick a Comp XE or XE-R lobe out of a book and call it their own. Then yes anyone can copy your cam.
BTW: Great numbers on your car. If you can get that package to repeat it'll be an awesome setup.
Paul
<strong>
And the T1+3? the Thunder 224/224 561/561 </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If the TR224 is a rip off of the T1 by your logic the G5 is nothing but a rip off of a C2 intake lobe and TR230 lobe on the exhaust.
The G5 is basically, a 224 XE-R intake lobe with a 230 XE exhaust lobe, bot the XE-R and XE lobes are lobes Comp Cams developed, at least TR developed their own cam from scratch...
While I understand your point, I think the T1 + 3 = TR224 is unfair, biased, misleading and without basis in fact.
Some of you won't accept a good thing when you see it. That is not my problem.
Some of you insist on trying to down play our numbers; the highest hp and tq from a NA cam and head package LS1/6. Keep in mind that it is a Package, including heads! And our G5 lobe was designed 1 year before the one that someone said we copied. Hard to copy what's not out yet.
The graph is up there. Take the Hp or tq numbers from any point, and plot them against the graph of ANY package out there and you will see for yourself. Don't just go by peak hp numbers. Look at and plot the power every 500 rpms. I Have.
First,
Comp does not grind our new cam, for exactly the proprietary reason. We didn't want everyone copying it. Our specs... and our cam grinder.
Second,
Our suspension parts were made 100% in my shop before my fabricator went racing. He now has MY jigs in his race shop, and builds them for me only.
Third,
If this was easy, then why has no one come up with hp numbers this high before. We have always had the highest torque numbers, and you all said that doesn't matter. (except HP=Tq x Rpm/5250) No torque....no hp. And don't forget Area under the curve.
But now we have the highest hp numbers. And unless everyone quits, it will only last for a while. 18 months ago the duscussion was all B1,T1. Then came the G5, and MTIs C1,X1, then the Thunder, and Katech, and MMS, etc, (Not necessarily in that order). And each time, all along the way, there were doubts. There were non beleivers. Myself included. Each cam works well for different buyers. I just sold a G5 today to someone who was not interested in high numbers, just reliable daily driver, with some thrill to it. (430+rwhp/420+rwtq worth)
But I realized that I was just getting lazy. So we worked harder until we came up with what we did.
There are still NO cam/head packages that match the TORQUE that we produced with the G5.
So, why do I hear sour grapes?
These results should make all the "tuners" get going and try some more combinations. That is called Competition. And that breeds better performance for everyone.
The LS1/6 engine is such a great engine design, and it was so easy to make HP with. It turned some backyard mechanics into "tuners".
Just call Lunati or Comp and get a cam, slide it in, and get more hp. Then came LS1 edit, so you can "twist the distributor, and change the jets" with a laptop. Now everyone is a "tuner".
Like it or not, the bar has been raised. And we are working on a new G5X-3 cam right now. We will not get caught asleep at the wheel again.
God bless America.
Thanks,
Lou Gigliotti LG Motorsports
Lou, congrats on the numbers. Are there any other cars lined up for this package install? I'd like to get an average set of numbers...taking into account differences in setups of course. Repeatability is key. No shop can give you a guarantee on numbers, so consistency serves as a pseudo guarantee.
BTW, I've seen some great results from your shop running N/A. Is there any development work with FI in the works? I know your racing pretty much centers around N/A...thus the specialization in such, but I was just curious. Feel free to PM/e-mail if you'd rather not advertise to the masses.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by G2 LS1:
<strong>
Paul </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Exactly what I was thinking, there are very few similarities between these cams except for maybe the lift is close <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
JS, BIG MIKE...What up my fellow peoples..lol
Curious, how does that car idle compared to a showroom factory stock 1998 WS6?
Can you tell the difference between the 2 if they sat next to each other?
