asa cam
I just put mine in a few days ago and love it. I've been tuning the idle and part throttle, haven't got to the WOT tuning yet. It idles well @ 900 rpm and never dies. I was on the freeway yesterday at 50 mph in 6th gear at 12-1300 rpm and it would still pull reasonably well. Revs happily to 6800 rpm. I haven't dyno'd it yet because I want to get the part throttle stuff down 1st, but it does run very hard. The valve train is as quiet as it was stock
I Have A Ls1 Hot Cam Like To Switch To Asa
I HAVE A QUESTION I HAVE A LS1 WITH A GM HOT CAM INSTALLED,I HAVE JUST BOUGHT SOME 243#CAST HEADS PORT/P.WHILE I HAVE MY MOTOR OUT I'M THINKING ABOUT CHANGING OUT MY GM HOT CAM I WAS REALLY NEVER HAPPY WITH IT ruff idel,my question is will this asa cam work with the same size parts pushrods ect? after all that was the reason while i bought the hot cam in the first place .o50 ? hook me up with info someone.js
just remember with the hot cam and asa cam.. if you ever look into buying heads, you can ignore the peak flow numbers at .600 and you can also ignore the flow numbers at .550 because you'll never see those numbers.
anyone running this combo?
how much over the 406hp I have now will it give me?
I ran both the Hotcam and ASA cam with 243 heads. The ASA cam made an additional 10 hp over the Hotcam. If you want more low end grunt, go with the hotcam. If you want more top end power pick the ASA cam. Both cams lope hard, the ASA more ofcourse due to the overlap and 110 lsa.
Is it auto or M6?
thanks
