asa cam
Originally Posted by GrannySShifting
asa cam is outdated lobe design for application not like then 99% of people run. you dont see it being run much, Ive only tuned a couple, and makes ok power.. but you can make same power with less cam, or more power with just as much cam
I would not mind seeing a couple of examples.
And how about the low lift what the ASA has. You can call it anything but a spring killer.
ASA head cam package
I loved mine! It put out about 410rwhp 400rwt on a crappy tune with 3:90, and high 11.xx afr. No worries on blowing lifters or springs or rod bolts, I only had to pull it to about 6400-6600(tach lag).
The technology is def. better now for overall power but this still carries its weight and imo, sounds better than anything else in its range.
!LS1 11 Second Club
ASA is amazing. An oldish grind with low lift making about the same power as a TR224 (sometimes even better). I'd consider using it for the low lift alone. Never change valve springs again.
With today's tuning, it's driveable daily.
Originally Posted by Damian
The ASA cam has the absolutely meanest TQ curve I have EVER seen in ANY LS1 application. Period. Not another cam on the market that makes a flatter TQ curve line than the ASA.
Tune
Originally Posted by white00ws6
sounds killer at idle thru my a4. lots of low end torque and hp as well. valve springs lasting a life time
Do you have a converter?
Thanks
