SLP has a new aluminum LS2/402 short block,is it worth it?
how good is this motor? would having it blueprinted make it better? $3,945,4340 steel crank,eagle h beam rods,ross 2640 forged oistons w/valve relifs and says will handle 700 natural aspirated hp. SLP says they sell it so cheep because they buy so many they get a price break and pass the savings off to the people. sounds like some nice parts.WHAT DO YA ALL THINK?
what about this for 4800?
6.0L iron LS1 block, fully machined, deck squared, torque plate honed, line honed mains, ARP main studs, Eagle forged 4.000 crank, SCAT 4340 H-beam rods, Diamond flat top pistons, Plasma moly rings, Federal-mogul bearings, Fully balanced, blueprinted, and assembled.
Originally Posted by mikey
Uses Chinese made Eagle crank and rods. Ross pistons. OEM main bolts. It's a budget block.
I was going to order the SLP motor, but decided to have it built locally. Cost only $500-700 more for the same parts.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The SDPC LS2 402 is machined and assembled by Sunset Machine Shop and is top notch.
Contact the user "Horsepower" here for details on the SLP block. He works for them and can answer your questions.
I must say it's pretty sad when a $4,000.00 short block is considered a "budget" motor. Maybe one day the prices will come down for these motors, but doesn't look like in this lifetime.
Originally Posted by mike c.
if the motor is solid,i was thinking the 402 w/afr 225 and the new g5x4 cam from LG would be a stout combo. oh yeah,lets not forget my t.n.t kit with it all ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
This post says the SLP motor is aluminum!!!!!!! I have not seen ads for the aluminum version but I have seen the iron-blocked 402 ads in magazines for $3600.
Originally Posted by smokinHawk
Lunati, callies, and ealge all come from china
I have heard all/most aftermarket LS1 crank castings come from pretty much the same place in china. But then finish work is done here. Also heard that a place over there will actually do the machine work also to those same castings, which could mean a super cheap 4340 crank coming soon.
Originally Posted by zamboxl
whats the sdpc part number i cant find it on their site anywhere
How many claims does SLP get for an alumium forged 402?
I saw some ads many months ago announcing the iron-blocked 402. It said you could get it in two different compression ratios. Is this possible with the aluminum versions?
