View Poll Results: Which engine combo to build?
Serious but streetable 383ci all stroke with AFR 225's
77
28.84%
402/408ci LS2 buildup with AFR 225's
190
71.16%
Voters: 267. You may not vote on this poll
Quick Poll.....
Old Mar 19, 2005 | 09:34 AM
ws6rufus's Avatar
Id like to see a 383.
Old Mar 19, 2005 | 09:35 AM
gaga's Avatar
Originally Posted by jrp
both
your still gonna do the 346 225 build up right?
exactly my thoughts!
Old Mar 19, 2005 | 10:36 AM
bigdsz's Avatar
402/408 Ls2
Old Mar 19, 2005 | 11:43 AM
99Transamman's Avatar
I would rather see the 402. I just put 205's on my 383 and it put down 497/460 thru a 9 inch and I'm going to put 225's on as soon as they come out to see the difference in them.
I will post my 205 results in dyno section sometime this weekend.
Old Mar 19, 2005 | 12:05 PM
FroDaddy's Avatar
Aren't you supposed to be working or something?
Back on topic... I'd like to see a 402.
Old Mar 19, 2005 | 12:17 PM
hc_performance's Avatar
402/408 ls2 for me too!
Old Mar 19, 2005 | 12:53 PM
SScam68's Avatar
Interested in a 383.
You should have made this into a poll where we can vote and see the results.
Maybe the admins can turn it into one?
Old Mar 19, 2005 | 01:07 PM
JMBLOWNWS6's Avatar
Tony the 402 setup we have with the AFR 225's is sick. We got the heads taken care of. The car made 550 rwhp SAE corrected. Ran it at the track and did low 11's and a 10.26 forgot the MPH on the NO2(150 shot). Thats with a M6. The car makes crazy power. So do the 402/408
Old Mar 19, 2005 | 01:37 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
GREAT idea....
Everyone that took part in the thread could just take a second to vote.
I didn't know how to do that....I'm sure one of the moderators will help us out.
THANKS!
Old Mar 19, 2005 | 01:39 PM
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by Tony Mamo @ AFR
GREAT idea....
Everyone the took part in the thread could just take a second to vote.
THANKS!
Adding a poll now.
Old Mar 19, 2005 | 01:56 PM
Kraest's Avatar
225 headed 230+ cammed 346
245/255 @ .050" 110* LSA 106* ICL solid roller
Please don't waste the 225s like that
Mike
Old Mar 19, 2005 | 02:10 PM
  #32
jrp's Avatar
jrp
SN95 Director
had you possed this question a year ago the 383 probably would of been the way to go. but with the massive interest in the aluminim 402's (just check SDPC's thread in the ls2 section), and the results mikey has shown with his 402 build ups its a no brainer. a 402 stroker shortblock will run you ~4500 after tax and shipping w/ no core. and with the new ls2 block people dont have to decide if the weight gain of the 6.0 iron block is worth just doing an all stroke 383. the 402 makes the most business sence as it will only grow in popularity especially after the KS issue has been worked out.
the 383 would be a nice build up but it seems to be catering to a smaller and smaller audience.
whatever you do Tony im sure its gonna be killer
Old Mar 19, 2005 | 02:27 PM
  #33
Flow Wizard
Good "summation" Jerami.....well said and I must say I tend to agree with that logic....the more I thought about costs (even considering I already HAVE an aluminum block), I started scatching my head thinking why wouldn't people opt for the larger bore motor....I didn't even consider the weight advantage in some applications which is huge in itself.
Old Mar 19, 2005 | 02:31 PM
  #34
Dave_62's Avatar
Well, I'd like to see both, but I know how expensive that gets. (Money and time wise)
The 402 since I have to choose. After I get the kinks out of my S-15 swap, that's probably the direction I'll take. As for the KS issue, Perry Kincy seems to be having good luck with them on the side of the block.
Old Mar 19, 2005 | 02:41 PM
  #35
jrp's Avatar
jrp
SN95 Director
thats what i meant, maybe just didnt word it properly. as stated a simple re-tap in the block for the ls1 KS is all thats required.
  #36
BAD FNZ's Avatar
Definately interested in the 402/8 build up!
Old Mar 19, 2005 | 03:47 PM
  #37
Nate_Taufer's Avatar
Nate
Old Mar 19, 2005 | 04:47 PM
  #38
The wife thinks I am working, If she finds out..
Old Mar 19, 2005 | 07:56 PM
  #39
ChucksZ06's Avatar
I am building a 402 (403 actually) using the 4.005 mahle pistons. I wanted the afr heads but tony was busy and I needed the small chamber heads. I am using a large cam with the patriot 2.08/1.60 heads...I have been doing quite a bit of cleanup porting and polishing the heads...a little more attention to detail and they would be great heads.
Old Mar 19, 2005 | 08:52 PM
  #40
Ru2n00n3er's Avatar
I would prefer a 383. When I build a motor for my car,probably three years away, I want to keep my block and reuse it. It's kind of a sentimental/emotional reason, but I'd rather build a motor with my block I have now than go for an entirely new engine, even if it means less power.
