Quick Poll.....
If you had your choice, would you rather see a fairly serious (but streetable) 383 CID build up with AFR 225's, or would you have more of an interest in seeing a 402/408 LS2 block build up instead.
Big Jimmy
Just finished testing a 383 that I will be posting flywheel dyno results shortly (chassis dyno #'s in a month or so), and I have a 415 CID LS2 build-up on deck next (same bore as a 402 with a 4.125 stroke)....probably see some numbers on that combination towards the end of the year.
I am digging myself out from a week's vacation....as soon as I can string together a few minutes, I will try and put together all the information gathered in my latest round of testing and share it with you guys. We cleared 600 HP with only 383 inches and slightly less than 11 to 1 CR....Impressive for a high compression race engine of the same cubic inch not long ago. Look for that and a lot more info in the dyno section towards the tail end of the weelk (hopefully).
Tony M.
Tony M.
600fwhp is going to be more than 500hp to the tires (depending on setup). I knew it was coming. Any early reports on cam???
Tony M.
Thats on pump gas with an 11.X CR and the TSP Giant Cam..
. following suit like the 346 build up the cam is quite mild for the combo, alot of guys are running more aggressive hyd. cams. i'll let Tony drop all the info though. The Best V8 Stories One Small Block at Time
This is what I've been dreaming about day and night for the last few months....an LS2 w/ AFR 225 heads and......on SPRAY!!!
https://ls1tech.com/forums/dynamometer-results-comparisons/384450-383-engine-dyno-results-graphs-included.html
You beat me to the punch....LOL
For those who might have missed it, I will also be featuring results from a 415 CID LS2 build-up next, so essentially you will have info from both types of combinations. I expect alot more TQ and a little more HP from that engine (also a lower HP and TQ peak). I'm very much looking foward to that as well and the results should be interesting....look for that information in the beginning of 06' (amazing how time flies....).
Regards,
Tony
