Quick Poll.....
365cid anyone?
You're gonna do a 402 Tony
come on... you know you are. Besides, I want to see how you get the C5 PCM to work with the LS2 knock sensors.While I have your attention let me say thanks again for your help on my A4 Vette with the 205's. Took it out for a run at the 1/4 last weekend. Even with just a 2800 stall and 1.85 sixty foot times I was turning 11.75's @ 120 MPH back to back. I even managed an 11.64 on one pass and if you are curious I was running MT ET Street Radials, 275/40/17.
You were right about the torque. I can't believe how hard it pulls and it's going to get better because I have a higher stall converter going in soon. This was the first time out on a 1/4 track with the new setup. It won me the Super Muscle bracket class at Hallsville (cars between 11.50 & 12.69)
It all works unbelievably well and it has fantastic street manners.
THANK YOU TONY!
Anyone looking for a streetable, torquey 383 set up could accomplish that using the 205 heads and short duration, tight LSA cam such as 226/226 110. Wouldn't be an optimal drag racer, but from 2000 - 5500 rpm you would have tons of torque and awesome throttle response.
more interested in what the 225CC heads will do on a large CI motor.....big CI/high RPM engines are the ones that are really in need of more head flow......I know thats what I'm waiting for before I dump $3K+ on new heads.........
the 383 would be a nice build up but it seems to be catering to a smaller and smaller audience.
whatever you do Tony im sure its gonna be killer
I never followed up with our little "exercise"....
The 402/408 is on the drawing board....Seems it was pretty much a landslide and the LS1 Tech community has spoken!
It will be with the new LS2 block (obviously)....just waiting on more input regarding the safe "bore limit" which will determine the final displacement.
I though it would also help me to perhaps share some information regarding the swap and what I encounter building and installing an LS2 based engine in my C5 (F-Body should be no different except for the TBW). I know ALOT of people are considering the very same move...
Thanks for all your responses....I was hoping to get a poll of significant "depth".
Regards,
Tony
