install time? Heads, cam install...
i got some TEA 5.3 heads, stg. 1.5 rev2, and a FMS F14 cam...i still have stock ls1 intake, pulley, and tb, but i think i should still make some decent power...i hate reading posts when ppl ask "what kinda power will this combo make, or will my car make?" but im curious to how much power ill be missing out on not having a ls6 intake, ported tb, and underdrive pulley? ill be putting in chromoly pushrods, single roller t/c, cam swap kit (gaskets and seals) and a ls6 oil pump as well...so what kinda minor details do i need to be looking at when doing this? some things a first timer might over look b/c of not having the experience or knowing what to look for? whats the adverage time most ppl take when doing this install? and what kinda power am i missing out on not having whats listed above? and ya, sure if you want to tell me what kinda power you think ill put to the ground after the install and a tune...sure go ahead and tell me, but im not asking!!
thanks alot fella's
Jon
take a good solid 3 days to do it...
It can be done by an experienced person in a day and a half...sometimes just 1 day...but common would be about 2 days....
Also, be VERY careful not to cross-thread bolts.
Jon
Having a friend help is the best advice in my opinion; it makes tough jobs, like removing the radiator and AC condensor (I recommend removing it), much easier.
Read www.ls1howto.com, but be ready to encouter obstacles and have things not exactly like the tutorial. Be flexible and make sure things are done right and it'll be all good.
Jon
Jon
i use this tool to remove 90% of the bolts on my car, that little bastard will remove every single header bolts w/out lifting a wrench (unless you have to break one loose). it will snake its way into anywhere. its the most used and best tool i own. if you have a good set of 1/4" drive sockets, 1/4 - 3/8 adapters, swivels, extensions, wobble extensions, etc. things will be easy. some bolts needs just the right combination of swivels, extensions etc. to get on them and be in a good position. the passengerside lower rear head bolt is a bitch, just telling you beforehand. the wrench wants to hit the a/c / heater thing and crack it while tightening it.
get a big wrench and a cheater pipe to make tightening those head bolts alot easier. use the sharpie marker across the heads method and do the specified 22 ftlbs - 90 degrees- 90 degrees (2 50degrees instead) method. make SURE the threads are clean, i put some tubing over my blower tip to blow most of the water out and also made a tap out of an old bolt (ls1howto) which worked awesome. be carefull with the sensors and clips.
be CAREFULL with the coolant temp sensor, the plastic AND the brass part will break off at a moments notice and leave you PHUCKED. make sure you get the gasket surfaces PERFECTLY clean. i used a shop-vac while i was cleaning so that nothing fell out of sight, just held the hose under where i was scraping and let the vacuum suck it up.
make sure you go somewhere that has lifetime tunes or somthing similar because you WILL need more tuning with the ported throttlebody and LS6 intake after the heads/cam tune.
Jon
thank you!Jon
