AFR 205's & Futral F6 Cam, your thoughts
Need a good daily driver street set up. Will see the track a few times per year. Dont need an aggressive idol or lope, more concerned with great tq. Would like more compression from the heads.
Ive seen a few people run the 224/228 duration cams with the 205's. Id like to squeeze a little more cam in and was wondering how much, if any i could mill the heads. I searched and found some info on the F13 AFR set up but cant find much about the F6 cam at all.
Cam specs are
FMS Custom Grind Camshaft ( F6 ) - 226"/230" .575"/.595" 114LSA - semi-aggressive profile with a 2000-6800 RPM range, fair idle
Will be running with FAST 90, NW 90mm TB, Kooks Headers, ORY, Magnaflow CB, Lid, HPtuners tune and stock 3.42 gears for now.
Thanks
Scoobs
Cam specs are
Thanks
Scoobs
LS1 Tech Administrator
You should make killer power. Just make sure you get the cam ground +2 and not +4. This will help you make the top-end power you need. Mill the heads and run a gasket to allow you to achieve 11 to 1 compression and you should be at or above 450rwhp with ease.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I have .040" milled AFR heads with Comp Cam 234/238 .595/.605 114LSA. With 1,000 miles on the new engine (forged LS6) I put down 443/397 RWHP/TQ through 4.10's. The intake manifold is stock LS6 and have Kooks with cats. If you decide to go with FAST intake set up, you should be over 450/400 easy. BTW it's a Y-body.
Cam specs are
Thanks
Scoobs
Cam specs are
Thanks
Scoobs
Either way I'm sure you will be smiling....I think this is more a personal choice you have to make regarding where you want to slightly favor your power curve and street manners.
Enjoy the AFR's...
Tony M.
He may have wanted the less-aggressive lobes for better valvetrain life. Then of course you have to increase duration a bit to get the same top-end performance.
Just an FYI....I'm completely comfortable with the aggresiveness of our cam for daily driving with our "out of the box" valvesprings we offer with our heads (the "gold" springs). For someone looking for the ultimate in reliability we offer the Comp 921 duals. Very expensive but you get what you pay for, which in this particular case is the tremendous amount of "QC" that goes into the 921, (hopefully all but eliminating the chance of failure). Word has it the 921's go thru most of the same testing as some of the Winston Cup springs that Comp offers. Our standard spring as well as our 921 springs are extremely reliable.
Tony M.
