Highest compression on pump gas?
Nitrous is not the same as a super/turbo charger. A supercharger or turbo compresses the incoming air, which allows for more fuel to be added, with the same AFR. With nitrous injection, there is no compression of the incoming air, only added oxygen from the nitrous. This also allows for more fuel to be added. The fuel/oxygen mix is what contains the energy to make power. The cylinder pressure in a turbo/supercharged engine is much higher before compression, due to the incoming air already being at a pressure higher than atmosheric pressure. You can think of this as effectively increasing the compression ratio. With nitrous, the cylinder pressure prior to combustion is not any different than without the nitrous, it does not effectively increase the compression ratio. Increasing compression ratio increases engine efficiency, therefore increasing power.
Therefore, while using nitrous, an increase in compression ratio will make more power and not increase cylinder pressure to dangerously high levels. With increased compression there needs to be an increase in fuel octane, to prevent pre-ignition. This need is increased by the use of nitrous, which makes the mixture more volatile due to the increased amount of oxygen.
I would suggest 11.0:1 or so, but I am no expert.
Exactly which is why 90 percent of the nitrous motors on this board are 10:5:1 or higher if they arent stock bottom ends...
Adrenaline-
The combustion chamber in the LSx heads is miles ahead of the old Vortec heads and other performance heads. In addition the beauty of fuel injection allows for abnormally high compression on 91 octane and a big cam with lots of duration bleeds off cylinder pressure. I'm sure that individual coil packs don't hurt either. GM really did their homework when building this engine.
After building 5 Buick Grand National engines and finally tearing apart an LS1... The LSx technology (reusable gaskets, oil pump driven off the crank snout, cross bolted main caps, good flowing factory casting heads with interesting port designs, composite intake (helps to lower intake temps over long periods of time) and other great features) is the best engine I've come across in making things more simple in an engine for a good reason. No complex 4 valves per cylinder, multiple cams, timing chains etc.
When there are hundreds of LSx people running 11:1+ on 91/93 octane I'd say it is safe to assume it can be done... even if a book says it can't. Carb'd setups and EFI yield different results when pushing the compression envelope on pump gas. The beauty of computer controlled engines.
-Mark
But soon I leaned the difference.
Tim
On the gas, if you start with 11-1 cr and spray it, the CR never changes, you motor just turns into a pump. so if your cam is perfect and your tune is correct, CR should be able to be run at 11-1 to 12-1 without an issue. and for safe messure, when racing throw a couple gallons in of race gas.
FWIW, my car is around 13-1, i run race gas, and 117 in my stand alone. when i run on the street to car shows and stuff and i know i will not spray, im running 93 octain pump gas with no issues. i dont do it much, but i do it.
Not sure who is putting the specs to this motor/cam ect, but be sure they know what they are doing, not just talking.
as you can see from a few of theses posts, anyone can talk like they know somthing.
Quit acting like you know it all Bro. He said (93 pump gas) and I gave him my answer.
N2O use is very tune dependent, so of course you have to reduce timing and add fuel accordingly while monitoring with data logger.
Do you even have an LS1?
Juicers all know that the higher CR the more power. Of course higher CR demands higher Octane.Quench plays a big role to.
Here I have 98 Octane premium and I can shoot 200 dry on stock motor without even pulling timing. Yes 28.8* with a 12.6 AFR and I could lean it a bit.
CR 10.4x
So please try to relax, trade info, learn a bit but avoid bashing, and acting like you are King of all knowledge.
Some BBC at the track here are running 14:1 and shooting 400 rwhp shot DP.
Edit: missed the last page.
My setup is alot like this but on a lt1 stroker with 11:5:1 and will be putting c16 in my stand alone.. My cam is a 236/245 114lsa .569/.580
My car is naturally aspirated using 9.7:1 compression and running 12's this year with this 1.6 rockers and new exhaust.
http://www.gmthunder.com/main/module...&p=44981#44981
The last motor ran 13.2 @ 105 with 248 HP at the wheel, street tires and
3761 lbs race weight. But you dumb punks forget to include that.
http://gmthunder.com/tino/dynograph.jpg
My 1st gen SB is surpassing your LS1. FWIW, with a slick, I'm destined for mid
12's ALL MOTOR. Ever wonder how that works with only 248 HP at the wheel smart guys?
But why do you people with no engine building skills always attack facts outside
of the debate?
What difference does it make what motor I have in my car, or how fast it runs?
That is such a typical reply for an internet car forum bench racer!
TY_TY13 posted some information and highlighted a paragrah that you all
need to read.
Get your head out of your asses and read the damn links! You can't run
93 pump gas with tons of nitrous and be effective.
You NEED to drop the compression, or resort to higher octane fuel.
What part of this do you not understand?
Let's take a little poll since the **** talkers are not smart enough to post cam specs:
Engine 1:
10.5:1 comrpession, DCR 8.5, 100 shot of nitrous, 93 pump gas, timing -4
Engine 2
9:1 compression, DCR 8, 250 shot of nitrous, 92 pump gas, timing -2
Engine 3
11.5:1 compression, DCR 8, 100 shot of nitrous, 93 pump gas, timing -2
Engine 4
11.5:1 compression, DCR 8.5, 250 shot of nitrous, 93 pump gas, timing -8
Which engine is stronger?
Which engine is not likely to work?
Which engine is just average?
Which engine is weakest?
SOrry, I'm not supposed to reply because I got owned?
Are you fools still sitting on your *** agreeing with each other becasue you're
all internet friends, or have you researched and called some engine tuners yet?
let's see your engine specs.
Did you actually cc the head, or did you use an online calculator to figure
Maybe you used that wonderfull program uhhhh...ummm...Desktop Dyno 2000?
Put it down in writing and I'll do some CR math for you and post it.
So nitrous doesn't increase cylinder pressure huh?
And all of you beleive that too?
Wow, this thread is getting stupid.
Is there ANYONE out there reading this with a half a brain that can read the
links and back me up?
Is there an engine tuner on this board that can back me up?
So I'm saying initially on page one, that 11:1 is about as high as you shuold
go with pump gas and 100 shot of nitrous...but now I'm owned because...
everyone said it afterwards?
I see how this works. I just can win because I worked in a speed shop and
don't have an LS1.
WHat if I run down the road to the local car dealer and pickup a used 'Bird,
or Camaro with an LS1. Will that make everything I typed true?
info.
Here's ANOTHER credible link to discredit all of you guys posting BS:
Have a read, it's good stuff!
http://www.noswizard.com/technical.php
I really like the part where they say, "adequate to fire a standard inlet charge effectively, never mind a charge at the higher pressures caused by injecting N2O. However it is easy to understand that as the pre-combustion chamber pressures rise due to higher volumes of inlet charge, the spark strength required to jump a fixed plug gap is also going to rise"
Oops, looks like a few of you got owned there huh?
Oh wait, here's another good quote regarding low compression, "e.g. you could run normally on lower octane fuel and put your engine under less stress), plus it brings the added advantage of raising the power potential of the nitrous system before problems are encountered. "
Geez, that's FOUR unique links and still nobody can prove me wrong.
I can't wait to read the replies when I get home tonight. Should make for
some good laughs.
(Again, sorry for adding four posts in a row. I have a huge internet image to
protect don't you know).
I love it when I'm right.
I think some people are mistaking my reply to say:
"reduce compression to run any amount of nitrous"
That is NOT what I'm saying.
If people were to read my very first post, I clearly stated that 11:1 with
pump gas is about the max before getting into detonation issues.
Check the knock counts if you're up around 11:1 SCR, and see if the motor
is giving full advance at wide open (this leaving about 8-8.5 DCR with IVC).
Being all aluminum, and the chamber design, the LS1 can probably handle
a touch more compression. I have no problem with that either.
For those that are telling Tim to rise over 11-11.5:1 on pump gas and spray
100 shot of N20 are dreaming.
That's not the best setup to run.
My position is this:
To run nitrous effectively, you need to consider the extra charge volume.
Much to everyone's surprise, nitrous adds a **** load of cylinder pressure.
The only saving grace is the chamber temperatures drop...so that may allow
slightly higher static and dynamic compressions than non intercooled boost.
Why? Because compression adds heat, heat can trigger early ignition.
When you stuff extra charge into a compression stroke (N20, boost), the
fuel becomes more prone to pre-ignition because of the higher charge
volume getting squeezed into that very same chamber size.
But that doesn't change the FACT that reducing the DCR/SCR and stuffing
more nitrous per compression stroke increases power.
Again, what makes more sense:
Engine 1:
OR
Engine 2
Now read back to all of those people who said, "Nitrous isn't like boost,
it doesn't change the cylinder pressure, or effective compression" and laugh at them.
Clearly, we are dealing with magazine mechanics here.
Pulling some timing advance simply moves this faster burning pressure wave out of the 'danger zone' (at or near TDC) and places it further along the piston's downward travel. Just the same as if you tuned your car with too much advance on regular old air, just back it out and move the pressure spike into that 'usable zone.'
