View Poll Results: F-13 Too Big for Daily Driver (Owners of F13 Only)
If anything go bigger!
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
64
35.96%
I am very happy with this cam. It is just right.
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
95
53.37%
I would go a little smaller if I had to do it again...
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
19
10.67%
Voters: 178. You may not vote on this poll
Poll: F13 too big for Daily Driver? (Owners Only)
#61
Originally Posted by FstBlkz28
Guys w/ the F13's ... describe the EXACT driveability of the cam. I'm looking at the F13 (230/232) and F11(228/230) right now. A switch from my Thunder Racing 230/224, and i'm looking for better driveability. Before yall start saying the F13 has badass driveability, can someone describe your typical cold startup / warm startup. What surging problems do you have, when its cold and when its warm. Whats the lowest rpm you can get it to idl.e at? In traffic when your coming to a light, what rpm does the car start bucking at in 4th,3rd,2nd? All these conditions when its got a good tune too btw, not on a stock tune.
With my tr230, at first I was saying the driveability was the same as stock. After driving it through almost every condition possible, I've noticed there are some areas where it doesn't have the stock driveability. And I'm looking for some basis to compare the driveability of the F13 to my tr230 other than "you can't beat the driveability of this cam".
Any detailed help is much appreciated!![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Keep in mind I've tuned mine, I am not a pro but I think I do a good job.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Mine starts the same, 30degrees or 100degrees, cranks and fires right up, immediate idle is very smooth and not jumpy.
Once it is up to operating temperate mine idles at 900, I could probably get it down to 850 but I haven't taken the time to redo it.
At light throttle conditions(1-5%Throttle) and at 1500rpm in 4th/5th mine surges a little bit, I have been fiddling with the timing but I believe it is a fuel issue. It really isn't bad at all. I did daily drive mine for a while when my beater car broke.
#63
Originally Posted by '99pewtert/aff
, aside from some surging at lower speed/rpms it drives totally like stock.
-Andre
-Andre
umm..did i miss something. This is exactly the kind of thing people want to avoid.
That statement is funny to me.
#64
#66
I just installed my cam like 2 days ago. F11 112LSA +4
The cam drives great at lower rpm's although the stock cam does better under 1400. That's right...the F11 is driveable from 1400+rpm LIKE STOCK and this is with my own tuning on Hp tuners. With a tune on a dyno i should see a slight increase in driveability and even lower rpm driveability. No surging here.
#68
Can anyone tell me the diff in lope between a TSP 225/225 on 112 vs the F13 on 112? I know the overlap is a LOT different. 1 for the 225, 7 for the F13, and 9 for the F14. Someone chime in and let me know, I am picking between the F13 and F14 when the time comes this spring/summer.
Oh yeah, and I am NOT picking a cam based on lope either! I was just curious as how they compare to the lil 225, which I thought had a nice sound to it.
#70
Originally Posted by Brandon
nothing horribly worse, a little more sluggish, but at those rpms it doesnt take alot of hp to keep the car moving..
#71
#75
Ya it sounds pretty good. i bet yours is at least twice as loud with that setup. Got any sound clips?
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#76
will the FM13 go well with My A4 corvette that will have 3:73 gears and a 3600 stall. i also have dynatech long tubes with x-pipe and hi-flow cats, vortex rammer CAI and corsa indy exhaust. im looking to get about 400rwhp with this setup with a good tune using ls1 edit.
