Only 320 rwhp w G5X3 and TPIS LT headers
I just installed a G5X3/114lsa and TPIS headers on my otherwise stock 97 C5 6 speed. The car only dynoed @ 320rwhp. Something seems really wrong hear to me. I know the stock heads and intake manifold would hold up some hp, but I did not think it would be that bad. I was hoping for somethig like 365-380hp.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by gnx7
This probably sounds stupid.... but you do have HPTuners or LS1-Edit to retune it right?
its probaly the injectors, they are probably all clogged, my friends T/A did the same thing when he swapped out injectors and he went from 310rwhp to 402rwhp.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
It could be a number of things if the car has been sitting for 7 months. It probably won't take them long to figure it out and I'm sure you'll be happy with the end results.
Originally Posted by No Juice
Who is tuning it?
something is defenitly wrong...unfortanetly it can be 100 differant things or a combination of things. id start with the basics....plugs/injectors/fuel pump possibly/tuning issue/your bad gas theory...illiminate your basics and go from there. no reason y you shouldnt be atleast 365rwhp+. whatever the case, it should show up on the dyno based on your air/fuel ratio they should know where to look.
goodluck and keep us informed.
The tuner told me the car feels strong to about 3500RPM then it gets a little boggy. That is why I am thinking it could be old gas(it sat for 7months). Do you guys think that bad gas could hold up the hp #'s that bad. Other than that the car runs fine supposedly.
