Need cam help
Old Apr 23, 2005 | 07:14 PM
white1's Avatar
12 Second Truck Club
Default Need cam help
I know with reg hyd lifters to stay away from used cams, but with the gen 3 motors is there any worry? Also is a ls1 vette cam the same as ls1 camaro, or 5.3 truck cam? Newbie please help
Old Apr 23, 2005 | 07:38 PM
smokeum99ta's Avatar
I bought a used g5x2 cam 2 years ago and had no problems yet !!!!! That dont mean all used products are good . Plus I got it from LG Motorsports and they claimed they would warrenty it if I had any problems. As for the vette cam being the same as a f-body cam i'm pretty sure they are expect for the zo6 (ls6) model vettes.
Old Apr 23, 2005 | 08:10 PM
prostock_bigblock's Avatar
I will try to give more info to make everything clear to u:-
vette\
97-98-99 duration 199/207 lift 472/479 117
00 198/209 500/500 115.5
01-02-03 198/207 467/479 116
01ls6 204/211 525/525 116
02-04ls6 204/218 555/551 117.5
camaro`s\
98-00 duration 198/209 lift 500/500 119.5
01-02 196/207 467/479 116
5.3 trucks \
99-04 191/190 457/466 115.5(99model)or114(00-04model)
Old Apr 23, 2005 | 08:22 PM
white1's Avatar
vette\
camaro`s\
5.3 trucks \
Thanks for the help. I guess I should have asked the question different.
I have a 2000 Z71 with the 5.3. I am shooting for 14's
I found a good deal on a few used cams and am unsure what would be best.
one is form a 2000 camaro. one from a 99 camaro ss one from a 99 vette and a custom 209/218 .544/.563@1.7 114lsa.
I do a good bit of four wheeling, so want low end power, and its a daily driver so good idle is important also. I don't speak CAM very well so I really appreciate the help. Also will I need a custom tune? If so will a hypertech tune work till I can save for a Nevson tune?
Thanks
Old Apr 23, 2005 | 08:37 PM
Thats fine .
anyways if u only have these choices and honestly they wont give u the big difference. though it will refresh your car . I dont have have any idea on the custom cam 209/218.
For me its not worth it to do these swaps , I would rather go for aftermarket if you r seeking low 14s . and must think to do beter than the 14s.
In short words these cams wont let u jump to the 14s unless u r spraying or something.
Old Apr 23, 2005 | 08:42 PM
well if u dont have any other choices go for the custom one .
I advise u to go to truck forums they would help more .
or try to contact .>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>
Old Apr 23, 2005 | 08:44 PM
here u got a great cam
Old Apr 23, 2005 | 08:46 PM
white1's Avatar
Yea forgot about truck forum. I know 14's won't be enough, but I figure little by little.
So you dont think the swap is worth the effort? The deal is killer thats why I was thinking. If its not worth it I'll wait and get a real cam. Just thinking I could wake the lil bastard up some. Thanks for the advise.
Old Apr 23, 2005 | 09:43 PM
2xLS1's Avatar
Would you happen to know the cam specs on the 4.8L and 6.0L Trucks, or are the the same as the 5.3s?
Old Apr 23, 2005 | 09:54 PM
white1's Avatar
Prostocbigbloc says 191/190 457/466 114. I don't speak cam yet so I need a little help Thanks.
Old Apr 24, 2005 | 12:47 AM
the 99-00 6.0 liter has the same 5.3 cam .
01+ 6.0 uses 196/207 467/479 116lsa
Old Apr 24, 2005 | 12:53 AM
ya the 4.8 00-04 uses the same 5.3 cam 191/190 457/466 114
Old Apr 24, 2005 | 01:10 AM
WS6 RULES's Avatar
The Vett cam has a smaller base circle. (I think that's what it's called?) So if you put a Vett cam in a Firebird or Camaro you have to use longer push rods.
Old Apr 24, 2005 | 02:04 AM
Cal's Avatar
Cal
Nope, the vette cam is different than either one. But all of the stock cams are so small it really doesn't matter; they need to come out so you can put a big one in!
Old Apr 24, 2005 | 02:28 AM
pdd's Avatar
pdd
Old Apr 24, 2005 | 03:02 AM
cyphur's Avatar
Old Apr 24, 2005 | 01:06 PM
vette\
camaro`s\
generaly no big diff , did u say longer pushroads
