'00 LS1 running unusually cool. Stuck thermostat?
My buddy's '00 SS started running unusually cold tonight. The temp gauge never went past the second line on the gauge and didn't get close to the 210 that is usually runs at. Also the heater didn't blow nearly as cold as it usually does. Could this be a stuck thermo? Thanks
Re: '00 LS1 running unusually cool. Stuck thermostat?
Well, if your thermo was stuck then you would actually get hotter, not colder. If your thermo doesn't open all the way then less coolant can flow thru the motor. I wouldn't worry about the dummy guage on the dash. It is not very accurate. Get a friend to Atap the car and see what the temp is.
Also if the heater is pumping out less than hot air, you might want to check the heater core. It could be plugged. Alot of the radiator flushers on the market will do bad things to the heater core. Just something to think about.
Andy
Andy
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by slow:
<strong> the 99+ LS1 (f cars) the temp gauge is just a dummy light, and should read 210 from the entire operating range.
Only the 98's work.
Ryan. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i think you're correct on that one
Only the 98's work.
Could be a stuck open t-stat. It would allow fluid to go through the radiator constantly thus always being too cool. My winter beater had the same problem once. Damn thing took 15 mins to get anything out of the heater, and would only get fully warm if it was idling in place (no air through radiator).
If it was stuck closed, you would be overheating.
I'd replace it, sounds pretty likely that's the cause.
Dope
Dope
Mine has the same problem and I think it is the thermostat stuck open. Drive it down the road and it does not get over 130 but if you stop for a redlight of let it idle for a while and it gets to 180 fairly quick.
Start it up cold, open the Rad and see if you have fuild flowing through the Rad. If you do then it is open and needs to be replaced.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by chikn:
<strong> Mines a 98 and will get up to 210 in an unusually long wait at the McDonalds drive thru. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yeap, the fans turn on around 210
My car normally runs 180, but thats because i have the ac on 90% of the time.
Ryan
Ryan
