Cam degreeing: dot to dot or TDC method?
Also, what would be the side effects of having your valve timing off by a few degrees (either advance or retard).
Good luck !
I made a special bolt to degree in cams on LS1's. The accesory brackets is in the way to degree a cam in car. The degree wheel is to big to go right on the crank. I welded a stud onto old crank bolt. That way I can turn the motor w/ the bolt & have a large degree wheel out on the stud. Works like a charm.
