LS1 Anti-Detonation Chamber Design?
I'm thinking about welding up my chambers to add some compression, but I want to understand the shape so I don't mess it up.
I don't like the idea of milling heads for several reasons.
promote swirl and fast combustion.
The tight quench and swirl gets more charge closer to the spark plug (into
the chamber), as opposed to between the head and piston.
I don't think you want to be adding material in the chamber. There isn't
much room, and you will be displacing charge volume.
If anything, drop the quench height by 0.010" to raise the static CR, or swap
pistons if you have the money.
Adding material to the chamber could also cause hot spots which may lead
to pre-ignition.
Also consider what the welding will do the the factory seat inserts. Post some pictures of your progress if you get stuck.
Good luck,
Richard
https://ls1tech.com/forums/generation-iii-internal-engine/274822-gm-afr-cnc-head-pictures.html
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
https://ls1tech.com/forums/showthread.php?t=274822
Is it normal practice to fill the chamber as opposed to cutting the quench
height?
IE:
Why would you want to displace 2 cc of charge, as opposed to pushing
the wasted charge from the quench areas into the chamber where it will
combust more efficiently?
IMO, and research, there is more torque available from 2 cc of charge, than
cutting 2 cc of combustion volume to increase compression by ~ 0.25:1
Decreasing quench height to raise compression seems to be the more effective
method.
I don't advise it unless you want to re-heat treat (expensive).
If your really stuck on a very efficient design you might want to give the AFR's some thought....radically altering your stock casting simply won't be cost effective when the smoke clears and will leave you with a compromised casting. Plus the AFR's offer you thicker decks and rockerstud bosses for an even better scenario regarding strength and longevity.
I'm not "pimping" AFR here as much as I am suggesting you do not weld up your stock castings....think it thru and do the math but personally I would advise you against welding up a set of stockers for no good reason.
I may be changing the heat treat in the area of the weld, but I'm also increasing the thickness of the metal in that area, so I'm not sure how much it would really compromise them.
With all due respect, why are you going ahead with the welding?
Matching every chamber is going to be difficult to say the least.
To jump one point of compression is a huge amount of fill. For reasons
mentioned earlier, you stand to gain more power by pushing the charge
into the chamber, as opposed to out of the chamber.
This will improve swirl and allow less timing (theoretically) by the same
compression ratio.
Have you considered a change in gasket thickness?
Do you have enough deck height to allow for 0.010" off the compressed
gasket height?
Is the short block clearancing good enough to run a tighter quench height?
Just some thought and alternatives before you begin.
Good luck...
Tony
PS....Heads are all over the internet for $2182 completely assembled and shipped to your door....Then offset that figure by what you could get by selling your current heads. Now factor in some given dollar figure on the machine work (decking the welded heads and ??...personal man hours you might end up spending and some given value on that, etc....you get my point.
I'm not looking to squash your enthusiam and would love to hear about your results assuming you move forward with it....just sharing some considerations that come to mind.
Adreneline_Z, if you look at the pictures of the AFR heads in that link, you can see that thy way I would be doing it would expand the quench area and push the charge into the chamber. Check out the "peanut" shapped chambers.
I may still give it a try at a later time, so I'm recording all the information I've gathered. Thanks for all the tips and advice.
Check out this write-up for another angle:
http://www.kitcarmag.com/techarticles/65298/index2.html
Correct me if I'm wrong, but the LS6 and LS7 have a tighter quench height
than the LS1?
