Have TEA 5.3L heads-what FMS cam to run?
I got a F13 cam during Futral's sale not long ago, and recently decided to go ahead and buy some heads. I am getting TEA stage 1.5 5.3L heads. Would you guys recommend upgrading the cam to the F14 or F15? I know guys have had good luck with the F13 and these heads, but I can't find to many with an F14 or F15 with these heads. Gomer has the F15, but he has slightly better heads. Any opinions?
Off topic, but I will help you out. I talked to Futral about this, they recommended a MAX mill of .010" Now, there are some guys on here that have milled more and it works. I ordered my heads with a flat mill (ie 0 mill), but I am going with cometic .045 gaskets. Futral recommended a P/V clearance of 0.100 on intake and exhaust, but they said you could go down to 0.080 on the exhaust. PM me if you want more details.
Our latest 1.5 has about .015 more piston to valve clearence than our last 1.5 head.
However when going with a large cam PtoV must always be checked.
I doubt there is 5 hp between the two cams so I would just run what you have.
