i want a cam with as close to stock idle that=good power
post up some good cams that have a close to stock sounding idle, and if any one has one of these cams post up the hp increase, i really like the oldman cam but im open to ideas
do a search for 'stealth cams' and/or 'sleeper cams' and im sure you will find lots of useful info on what you're looking for. vid/sound clips, numbers, reviews, etc..
hope that helps
hope that helps
A good tuner can pretty much make any duration cam under 228 sound damn near stock. I've heard a TR224 114LSA idling at 925rpms and I could not tell it had a cam. My TR224 112LSA is set to idle at 875 rpms and thru the cats there is only a slight lope. You would have to know what your listening to, to be able to tell the car had a cam in it. The average person would have no idea. With the needed boltons and tuning the above cams are capable of 390+rwhp on stock heads. HTH
I'm running a comp 224 xe-r thru my stock slp catback and i think its sounds pretty stealthy which is what i was going for. i'm running long tubes and when i open up the cutout it sounds like a totally different beast
![Suspicious](https://ls1tech.com/forums/images/smilies2/suspicious.gif)
