TSP heads and cam package question!!
right 1quickt-a?
But, like I already said.. TEA does really good work from what I've seen and I'm not knocking them or their shop at all. But, I think TSP is a good shop as well and the guys @ TSP have done alot of stuff to help out some friends of mine here locally. I'm gonna try the PRC heads and see how it goes.. If they don't perform I'll be happy to tell everyone about it..
Since TSP has access to TEA heads (they sell them), why not do a flow comparison on their bench and post the results??
Or better yet, take them to an independent shop, make sure they are flown with intake and bent pipes (to simulate header) and then post results.
I've yet to see independent tests showing what manufacturers advertise (just so happen they always advertise higher), one exception are AFR heads which have damn close results, no matter where you flow them.
I ended up with the PRC 2.5's and the 233/239 R2 cam. The port work on the heads looked very nice and all the assymbly was perfect. I had a hot cam in the car before with stock heads. When I put the PRC's on I switched back to the stock cam so I could pass emissions/inspection. With the stock cam + the PRC's the car pulled just as hard as it did with the hot cam alone. Then I threw the 233/239 in there and it pulls like crazy all the way to 6500. This is a great combo at a great price for anyone wanting a 5.3 head with a cam you don't have to cut the pistons for. Haven't had a chance to dyno but I will post results once I have them.
Also I want to thank both Jason and Jon for all the help they gave me. They are two of the nicest guys I have ever dealt with.
I would have to agree with that!! And I've got that same setup and can't wait to get it all put together and see what the bitch does!!
