arp head stud kit vs. stock head bolts
I am about to install my tea heads and I have a brand new set of stock gm head bolts, but I came across a buddy whom is willing to give me a used arp stud kit that was install once and then removed. Which will be a better fastener the new gm bolts or the once used arp stud kit?
Originally Posted by sandking
I heard that the studs are only good for two installs/removals, if thats true, then you have the same life span for each.
Moderator
if you are sprayin the car or have some sort of F.I. set up than there is nothing else like head studs, eather way the studs work alot better and they are reusuable...... go with the studs
studs all the way, and definately cheaper in the long run, even if you did have to pay for them. plus the BEST part about them is that its 1000x easier to line up the heads. no more holding those ******* in place while trying to thread the bolts in
Originally Posted by ChameleonBird
what kind of lube do I need to coat the threads with before install and what are the torque specs from arp
