ummmm
Old May 18, 2005 | 05:51 AM
150shotWS6's Avatar
Default ummmm
Anyone know what would be a perfect cam for nitrous? About to run a 100 or 125 shot!
Old May 18, 2005 | 05:53 AM
150shotWS6's Avatar
O and I have stock intake!
Old May 18, 2005 | 01:02 PM
00TAProject's Avatar
Read around or do a search on that man...I have heard some saying 100shot is fine on stock internals and cam......But if your looking for a cam...There is no reason not to get one!!
Old May 18, 2005 | 01:25 PM
GuitsBoy's Avatar
Nitrous will work with any cam, so you could choose a cam that will give you good n/a numbers too. Otherwise if you want a cam that shines specifically on the juice, look for a split duration cam with a lot more exhaust, and limit the ls1 to 114. Check the nitrous forum for better info.
Old May 18, 2005 | 01:36 PM
2000TransAmWS6's Avatar
typo... i believe he means LSA
i was wondering the same thing that 150shotWS6 was asking about. i did a couple searches and didn't find what i was looking for,... maybe i need to search some more.
i've been told that cams that get the most out of nitrous have a duration (@.050) around 215-225, with an LSA around 114.
i don't know how true this is, maybe someone can chime in!
Old May 18, 2005 | 01:44 PM
GuitsBoy's Avatar
Its my new 114 ci LS1 Its a 1.4" stroke crank and the engine revs to 15K RPM. Makes 14 ft lbs of torque and 25 peak HP @14K rpm. Im gonna try and market it to gm so they can get the cobalt to keep up with the hondas. Okay okay, yes, i meant LSA... Im just too used to typing ls1 i guess...
Old May 18, 2005 | 02:00 PM
thats alright dude, i knew what you ment
Old May 18, 2005 | 02:54 PM
Blue Hawk's Avatar
BTW, I agree with you. Cam should be choosen in function of N/A goals. Nitrous is just the icing on the cake.
150shotWS6, you'll spend 99.999% of your time without using the juice, so unless it's a drag racing only car, you should focus on the power goals and manners of you engine without nitrous.
Old May 18, 2005 | 03:36 PM
RTCamaroSS's Avatar
i ran a 100 shot with the ASA cam (226/236 .525/.525 110LSA)... I gained 118rwhp/210rwtq from just a 100 shot Im about to see how well nitrous works with a trex.. i guess we'll see...
Old May 18, 2005 | 03:38 PM
JakeFusion's Avatar
Super Hulk Smash
G5X3-114. 'Nuff said.
Old May 18, 2005 | 04:38 PM
raul602's Avatar
NUFF SAID!!!
Old May 18, 2005 | 05:03 PM
150shotWS6's Avatar
Does it have to be 114 LSA. I seen some at 112! And I been searching but what is a good web site to find a cam of my needs?
