View Poll Results: What setup of a 408 would you pick?
#1- Build motor completely N/A for ever. With 11.1 comp. Shooting for 500 hp/tq
90
23.14%
#2- Build motor with blower parts and low compression so in (2 years) you could get a blower.
76
19.54%
#3- Build motor same as #1 but add some nitrious type parts and then maybe put a bootle on it.
223
57.33%
Voters: 389. You may not vote on this poll
Poll: What type of 408 would you build?
Old Oct 9, 2005 | 07:47 PM
  #61
Superman09's Avatar
LS1Tech Sponsor
Im curious about getting a 408 built. Approx what does Futral cost to build a nice 408 for 500 ish threw an A4? Someone give me a rough price please.....
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Oct 11, 2005 | 06:48 PM
  #62
Rhino21149's Avatar
My son put a 408 FE short block built by Horsepower Engineering in Houston with AFR big-port heads into our '98 Camaro. At 11.5:1 it will never run any supercharger but it will have a lot of nitrous on it.
On the other hand, I did a compromise on my ZO6: had a C5R block 427 built up for it with only a 10:2 c.r. so I could supercharge it at bit. ((I had a Magnusen on the stock 346 (((10.5 c.r.)) for two years before I replaced it with the 427 - it would run up to 6.5 lbs of boost with no detonation on pump gas: I figured the 10.2 would give me good power initially and I could eventually get at least 7-8 lbs of boost on it , maybe more).
It did not suffer that much N.A. because of the lower compression ratio: 507 RWHP through cats and full exhaust vs. about 525-530 I would have expected at 11:1 (I don't have an extreme cam - driveability and low end torque are the goals). I just put a D1SC on it and have been changing pulley sizes slowly, sort of sneaking up eventually to whatever gives me detonation.
Old Oct 11, 2005 | 06:54 PM
  #63
Rhino21149's Avatar
We bought a 408 FE short block with Eagle internals for something between $3.5K and $4K from Horsepower Engineering. My son did the rest of the assembly himself. AFR heads with some upgraded valves were about $2.2K - I'd recommend getting them polished and smoothed though - they had more "ripple" from the CNC finish than I liked. Everything else including shaft mounted rockers and a big cam and lifters including headers ran about another $3k.
Old Oct 11, 2005 | 09:16 PM
  #64
black01_WS6's Avatar
I would go H/C and shoot for 500hp. that is more than enough for the street, but if you are going racing I would use a turbo.
Old Oct 11, 2005 | 10:12 PM
  #65
RedSlpZ's Avatar
N/A Gets my vote.
Old Oct 12, 2005 | 02:42 PM
  #66
2000 Tran Zam's Avatar
all depends on what extent of upgrades you want, but i think my base was like 5-7k or so.
I can remember off the top of my head.
Old Oct 13, 2005 | 03:25 PM
  #67
Ragtop 99's Avatar
Build NA. 500 rwhp is a lot of power. You can always add a 100 shot once you have the suspension and tires to hook it up. Building a nitrous motor doesn't make sense unless you are certain the rest of car is going to be set-up to handle over 600 rwhp.
Old Oct 13, 2005 | 03:47 PM
  #68
Shane_G's Avatar
Turbo.
Old Dec 16, 2005 | 12:15 AM
  #69
bluey2kz28's Avatar
I would go with the low compression option and a D1SC plus other goodies.
Old Oct 5, 2008 | 06:23 PM
  #70
odarabla's Avatar
Originally Posted by George C.
First thing... call Allen Futral.
He can give you around 550 RWHP NA. I know... because he just did mine. Very, very streetable and it screams.
I remeber that car there. He also did my motor. Allen really knows his ****. My car is a stock bottom end TFS heads, Futral custom cam, all supporting mods for H/C/I, Built 4L60E with a PTC4400rpm stall, Strange 12 bolt with 4.11 gears. The car has ran a best of 11.30@120mph with a 1.5460ft. and she has some left in her. It's right on par on where Allen said it would do..
Old Oct 5, 2008 | 06:45 PM
  #71
SoxXpupPeT's Avatar
N/A built for alittle spray just in case
Old Oct 5, 2008 | 10:01 PM
  #72
RacerXLs1's Avatar
#3!!!!!
Old Oct 5, 2008 | 10:44 PM
  #73
novaflash2002's Avatar
Build it with 9:1 compression, and sacrafice that 35 hp and 40fptq, and turbo that s.o.b hard!!!
Old Oct 6, 2008 | 11:15 AM
  #74
AU N EGL's Avatar
Lots of good options posted.
I am a fan of NA.
My choice:
LS2 402
AFR 205s milled to 60.5
Still working on cam possibilities:
224/230 609/604 110+2 XFI
224/228 581/588 110+2 XFI / XER
or ??
Daily Dry sump system
Fast92/92
Compression hopefully in the 12:1 range or more?
run 100 octane or E85 Race fuel ( not the pump crap )
Old Oct 6, 2008 | 08:32 PM
  #75
Kingc8r's Avatar
Holy thread resurrection
Old Oct 6, 2008 | 11:30 PM
  #76
bigdsz's Avatar
Erik at HKE built my 408 in the sig below. Only 11.3 compression, but still managed to get 524 rwhp on a conservative dynoand a 9" rear.
Old Oct 7, 2008 | 06:48 AM
  #77
AU N EGL's Avatar
Now that is good advertising. Very cool
Old Oct 9, 2008 | 10:31 AM
  #78
99Ls1fever's Avatar
I went with a 408 and thought it would also be two years before I got a boost application. Now in under a year just keeping my ear out I have a D1SC and a 408 trust me it was worth the wait.
Old Oct 9, 2008 | 10:41 AM
  #79
99Ls1fever's Avatar
How do you like that 100mm MAF I have been looking at a few of them?
Old Oct 10, 2008 | 07:13 AM
  #80
bigdsz's Avatar
I went with the Lingenfelter 100mm, because the outside diameter was a few mm smaller than the others. Since TSP never made their 100 lid , I was able to use the Fast Toys lid that I modified. I seriously considered SD but my tuner Mike Norris discouraged me.
