Cheatr Cam...
Old May 27, 2005 | 12:44 PM
  #41
Geoff's Avatar
Originally Posted by Vortech
Geoff what do you think the cheatr cam is worth over the stock 02Z06 cam? Is there maybe something more optimal for the Z06 do it's freer flowing exhaust? There's like a 10 degree difference in duration plus the added lift which would take advantage of the AFR's. I'm guessing at least 10rwhp-what do you think? Man that would be like 424 or like 480 horse out of a 346-man these motors are badass!
I don't like to over commit on the HP numbers. IMHO it should do better but without back to back testing I don't have a solid answer for you.
Old May 28, 2005 | 01:06 AM
  #42
PREDATOR-Z's Avatar
Originally Posted by Geoff
I agree. Personally I still think the Cheater cam will have more potential than everyone thinks with headers. This is just speculation on my part at this point, however. Jason is putting headers on his car in a couple of weeks. At this point I think we will have some solid answers on what this thing will do cam only.
The Cheater will like nitrous better, that is for sure.
Basically like Geoff said, if you want to remain inconspicuous , the Cheater is a great addition to the "Stealthy" cams allready available on the market.
Old May 28, 2005 | 08:41 AM
  #43
JS's Avatar
JS
So is the 02 cam with about 2 to 4 degrees advance into it...GM knew what they were doing with this cam,I;ve just seen a guy dyno 414RW threw manifolds running AFR's and the 02 LS6 cam...
Old May 28, 2005 | 07:56 PM
  #44
eb02z06's Avatar
So when can we get a group purchase on this cam. Anyone interested?
Old May 29, 2005 | 03:05 AM
  #45
TT_Vert's Avatar
any idea if this cam would work well on a c5 w/ its exhaust? I dont know how similar the fbody exhaust is to the c5 exhaust.
Dave
Old May 29, 2005 | 04:16 AM
  #46
Scoobie's Avatar
Geoff, i ordered the CheaTR cam through Paul during the freaky friday sale, im assuming it will be here soon.
Currently Im running a set of Dynatech Longtube Headers, a SLP lid and a FAST 90/NW 90 TB set up. With the stock catback and these mods, i trapped 109.4 mph tonight. I will be installing a magnaflow catback wednesday and the Cheater cam shortly after with stock LS1 heads. Ill dyno and take her to the track when its all done and post up the results. Ill be doing AFR heads then after but need a clutch and tires first.
-Scoobs
Old May 29, 2005 | 04:55 AM
  #47
BriGuy's Avatar
Originally Posted by Drew778
Is your cam the MTI stealth?
Technically yes it is. Although I did not purchase it through MTI. I was keeping a close eye on this board back when Colonel was testing out that cam, right before MTI starting making it. So, when I saw that Colonel liked it I went through Combination Motorsports to get the cam.
Old May 29, 2005 | 10:22 AM
  #48
UtOhCop's Avatar
Dave
The C5 exhaust isn't that much different. Numbers in sig.
Old May 29, 2005 | 11:58 AM
  #49
TT_Vert's Avatar
thanks utohcop. What did your car run stock. Or without the cam. What heads do you have? Any before/after dyno #s?
Dave
Old May 29, 2005 | 08:46 PM
  #50
SStrokerAce's Avatar
Way to go to support the guys who did the R&D and came up with the cam!
And people wonder why some places keep their cam specs secret!
Old May 30, 2005 | 12:26 AM
  #51
BriGuy's Avatar
Actually the only thing that I did take from them was the LSA. Considering that I wanted something that was going to be quiet and stealthy. Because the cam was ordered from Combo's website. But instead of ordering with the 112 LSA I ordered it with the 116. I had completely forgot that it was on the website when I made my original post.
Old May 30, 2005 | 03:32 AM
  #52
JS's Avatar
JS
I've been bouncing cam ideas for weeks now..I came to the conclusion for me,the 02 LS6 cam adv 4 degrees should be the ticket..I'll be doing either Edlebrocks,AFR's or TEA S1.5 with this setup along with a March pulley and Ptb threw ported manifolds...
I'm hoping for 380RW threw my A4 GTO...
Dead stock idle with lots of TQ
Old May 30, 2005 | 04:57 AM
  #53
PREDATOR-Z's Avatar
Specs at .050 tel you squat.
224/220 .581/.581 116lsa (Stealth II).
If you order that through any manufacturer, that doesn't mean you have a copy of the original.
You have to know all the VE's and EVOs etc.. to duplicate a cam.
The only way to clone a cam is to Cam Doctor the original and then duplicate it.
Old May 30, 2005 | 01:01 PM
  #54
TT_Vert's Avatar
does anyone run this cam w/ a 5.3L head? Any P/V issues? What length pushrods are you guys running?
Thanks
dave
Old May 30, 2005 | 10:52 PM
  #55
REDLYNER's Avatar
After reading this thread and checking out TR's site, I'm really interested in this cam.
Do I need to buy the cam package TR offers for the install? It comes with:
- cheaTR cam
- Comp Cams 26918 Valve Springs
- Thunder Racing Stock Length Pushrods (7.400)
All for $599. Is this the best way to spend my money? I'm still stock headers/cats/titanium exhaust. Also, will I need retainers? I am on a budget, so if I don't need it, I'm not going to buy it! Installing myself.
Thanks!
Old May 30, 2005 | 10:57 PM
  #56
TT_Vert's Avatar
im also wondering if this will clear a 5.3L head
dave
Old May 30, 2005 | 11:33 PM
  #57
Yeah you are right, that's another reason some people keep cam specs a secret. If you get the lobes wrong the cam will be worthless as well. The valve events are important but what the lobe does with the rest of the parts is just as important.
Bret
Old May 31, 2005 | 06:15 PM
  #58
Jared H's Avatar
Geoff/Patrick,
Would this cam work well with a set of LPE Ported LS6 heads milled .030? Would P/V clearance be an issue here? What valve springs would be recommended? Any idea what length pushrods with the stock LS6 valves? I will be buying a cam soon to go with my LS6 heads and I am very interested in this cam if it will work for me.
Thx for the info ... JHH
Old Dec 24, 2005 | 02:03 PM
  #59
bluecamaroz28's Avatar
Anyone tried TR Cheater-Cam with long tube headers. Is it performing or falling short compared to stock manifold?
Any dyno numbers.?
Old Dec 24, 2005 | 02:54 PM
  #60
Patrick G's Avatar
LS1 Tech Administrator
Any dyno numbers.?
The CheaTR has performed exceptionally well with headers too. Just type CheaTR in a title search and you will see the results.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
