Best low end torque cam for LS1..
Old May 29, 2005 | 10:25 AM
Patrick G's Avatar
LS1 Tech Administrator
You may want to look at a cam like the Ausies's run: Keep the intake duration on the shorter side and run a much narrower LSA. Maybe something like 216/220 108LSA (+0). This would make OMG cylinder pressure and big block torque down low and pull nicely to 6000 rpm. The Ausie's are much further along with low-end torque cam development IMO.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 29, 2005 | 10:37 AM
Red91vette's Avatar
I am in the same boat you are, I want low end torque, im not looking to rev the car up high just ot get more power but have nothing down low. I am waiting for the roots style blower to come out for our cars. Apparently there are two companies making them, so hopefully it will be somewhat affordable, start saving now! Full boost basically off idle, talk about low end torque!!!
Old May 29, 2005 | 11:03 AM
Keenov's Avatar
Originally Posted by WildBills WS6/SS
you should be making more than that
Glad you care.
Old May 29, 2005 | 11:05 AM
SSCoulter's Avatar
216/220 108LSA (+0)! Now that sounds interesting. I'm glad you guys understand what I am wanting from this car. I own this car for my enjoyment and the more torque the more fun it is to drive. I have a 2005 Dodge Ram 2500 with the Cummins Turbo Diesel and it makes over 600ft pounds of torque. Talk about fun to drive! I look at my SS like I used to look at my bike. The whole point of driving it is to have fun. I will never have the fastest LS1 in the world, and I don't care. I want the fun meter pegged when mash the gas. I want it to look good and sound good. Yeah, that's what I want.
Old May 29, 2005 | 11:06 AM
PREDATOR-Z's Avatar
This is why I quoted the following:
Originally Posted by PREDATOR-Z
FRom the description you're giving of the power range desired I would check VINCI/Crane Variable lift cams.>>>>>>Sponsors.
The 047 cam fits that pretty well.
Old May 29, 2005 | 02:07 PM
RevGTO's Avatar
Pontiacerator
Funny how so many guys on this site can't help but recommend "big" and can't stay away from talking peak hp. I'm interested in the same thing as you are. Besides the Vinci cams which have been mentioned, I would look at the TR "old Man" cam, their new CheaTR cam (especially with stock manifolds) and the Comp 216/200.
Old May 29, 2005 | 03:28 PM
demonspeed's Avatar
It's not mine! woo hoo!
The more popular "big" cams still make generous power throughout the powerband - even moreso than some smaller ones do.
Old May 29, 2005 | 03:48 PM
d james's Avatar
magnasum is also looking at building a eaton as well, I've talked with them a few times about it, and they are very interested in it, unlike before where they told me they tried and it can't be done-I'm glad they changed their tune, also it should be cheaper than the the other companies making them, magnasum told me should be priced along the lines of thier truck kits.
There was a car magazine that did a comparo of different comp cams, and even the bigger ones sitll made more low end torque than the stock cam throughout the rpm band. I think it was the 216/220 that was the biggst you could go without losing, the bigger cams still made more low end torque than stock I believe, but they weren't as much as the 216/220. The bigger ones sacrificed low end for some high end power. I'll see if I can find the link.
Old May 29, 2005 | 04:07 PM
d james's Avatar
heres the link to the comp cams http://www.compcams.com/Community/Ar...ID=-1044516358
Old May 29, 2005 | 04:38 PM
1QuickT-A's Avatar
The TSP 225/225 cam would be a good choice as well as some of the proven Futral Cams..
Old May 29, 2005 | 05:12 PM
SSCoulter's Avatar
Originally Posted by d james
Thanks for posting that, it's a good read.
Old May 29, 2005 | 07:05 PM
  #32
blkZ28spt's Avatar
Why are you afraid to rev past 6k rpm? In an M6 with 4.10's you shouldn't have a problem with the larger cams.
You said you want to peg the fun factor when you mash the gas, the larger cams will definatley do that for you.
I've always liked the look of the FM14, or maybe the FM13.
Old May 29, 2005 | 07:32 PM
  #33
DaddySS's Avatar
Yes but the smaller cams are more generous with the power at the lower range. Short duration (200 to 220) high lift lobes with a wide LSA make more low end torque over a wider range than the bigger cams - yes?
Old May 29, 2005 | 08:28 PM
  #34
SSCoulter's Avatar
I didn't say anything about being afraid to rev past 6,000. What I said was I don't do that very often. Big picture here! How often percentage wise do you rev over 6,000? 99.999999% I am between 800-5500. I want a cam that performs there in that range. You may be right about the bigger cams, but there has to be a trade off. Higher end performance means something, somewhere has to suffer. I don't want to change springs every 10k and as I said before I don't give a rat's behind about my 1/4 time. I drive this car for my enjoyment. I've bounced the thing off the rev limiter many times. I'm not worried or afraid to take it to the top, I just don't drive that way very often.
Old May 29, 2005 | 08:35 PM
  #35
blkZ28spt's Avatar
They way I drive I tend to either be below 4k rpm or at WOT up to my 6500 shift points. I wouldn't know about driving up to 5500 rpm.
You just seem to be exaggerating and taking things a little too far. Not sure if that is just how you percieve it though. Example: You say you don't want to "change springs every 10k miles". On that statement:
1) Even big/aggressive cams don't require 10k miles per spring swap.
2) You want a lot of torque you are probably going to be just as hard on your springs as the BIG cams. Gobs of torque usually goes along with aggressive ramp rates, which in turn wears springs out quicker.
Try an FM13. I think you'd like it. Can't go wrong with the TR224 though.
Old May 29, 2005 | 09:53 PM
  #36
SSCoulter's Avatar
Don't take what I said the wrong way please. I'm not trying to argue, I'm trying to illustrate a point. I'm just trying to be clear with my thoughts. In my real world driving I am usually under 4k like you say you are. If get on it for fun, or like if I'm getting on the highway etc. I like to run it on up there sure. Shift points? My shift points depend on where I am and what chance of getting pulled over by the PD are. If I am out in the middle of nowhere or at the track, yeah the shift points are as high as possible. (You don't shift based on what your lazy factory tach is saying do you?) I shift when I hear the motor telling me it's time to shift or when I think my loudmouth has made enough noise in the area I happen to be in. The rpm's are not the focus here rather how I drive this car the majority of the time is the focus of this thread. BTW, I only made the reference to having to change the springs every 10k because I have read that it is a issue. (i.e. the LS1 hotcam is easy on springs, etc.) The whole point of this post was to get some input on what cams are making good usable power in the lower to mid rpm range. Most of the post here seem like they are focused on the absolute max power top-end numbers wouldn't you agree? Yeah that's cool that you made xxx hp on the dyno, but what about the real world? In this sea of big cams, I was looking for the right cam for me not the biggest, latest, greatest cam that's all.
Oh, and thanks for your input. It's starting to look like I am back to my first choice which is the TR224.
Old May 29, 2005 | 09:58 PM
  #37
blkZ28spt's Avatar
I understand. The bigger cams ARE faster, but only if you support them with big stall/gears. Springs with just about any aftermarket cam will need to be changed after 15-25k miles, depending. I do know better than to trust the tach, I have an A4 that is set to shift at 6500 rpm. FWIW: After first gear it does a pretty dang good job of keeping up and usually shifts at what appears to be 6500.
I see no reason why the TR224/112 you first posted up wouldn't suit you very well. It makes good low/midrange and is capable of 400 rwhp with all the bolt-ons and a good tune.
Old May 29, 2005 | 10:03 PM
  #38
SSCoulter's Avatar
Thank you very much.
Old May 29, 2005 | 10:32 PM
  #39
demonspeed's Avatar
That is something I honestly couldn't answer since I'm still trying to learn about cam profiles and such. I'm just saying from what I see with dyno sheets and track performance, I really don't see that the bigger cams are simply just "peaky".
Old May 29, 2005 | 11:43 PM
  #40
blkZ28spt's Avatar
I too am definately in the learning phase, but from what I can gather most of the larger cams really arne't what I would call "peaky". Some people seem to go too far and say they have no power down low but that's really not the case. They may not make the best power down low, but it's usually adequate and IMO justified by the stronger top end. Or so it seems...
