MTI/AFR Stage 2 flow comparison
Old Jun 7, 2005 | 01:40 PM
Anniversary "Z"'s Avatar
Default MTI/AFR Stage 2 flow comparison
Since I have a set of both I decided to get flow numbers on both to compare:
MTI Stage 2 heads
.100 - 65/55
.200 - 131/98
.300 - 189/141
.400 - 231/175
.500 - 265/199
.550 - 276/211
.600 - 277/218
.650 - 277/222
.700 - 277/224
AFR 205 Stage 2
.100 - 61/50
.200 - 133/108
.300 - 198/158
.400 - 236/204
.500 - 276/221
.550 - 287/227
.600 - 294/232
.650 - 296/235
.700 - 298/235
Old Jun 7, 2005 | 02:10 PM
JZ'sTA's Avatar
Was a pipe used?
Clay radius?
3.0 bore?
What kind of bench?
Weird how the MTI heads flow 277 from 600-700
Old Jun 7, 2005 | 02:12 PM
CHRISPY's Avatar
I'd like to know the intake and exhaust volumes in cc's on the MTI head.
Old Jun 7, 2005 | 02:25 PM
Originally Posted by JZ'sTA
Was a pipe used?
Clay radius?
3.0 bore?
What kind of bench?
I'm not going to be much help here except the fact the two sets were flowed on the same bench by the same guy consecutively. I thought that was kind of interesting that the intake was tapped out @ .600.
I don't have specific volumes on the intake and exhaust but these are the Stage 2R heads and are milled .030.
Old Jun 7, 2005 | 02:27 PM
00RedWs6's Avatar
Stage 2E or Stage 2R for the MTI?
Old Jun 7, 2005 | 02:30 PM
Phil'sC5vette's Avatar
Im on the market for heads. That info helped a great deal
My TR224 only has a lift of .564 so any numbers above that dont mean jack to me. There arent to many cams out there with the lift of .600.
Even though Id lose about 10 CFM looking at both heads at .550, im ok with that and the $1000.00 dollar savings.
That is if both heads have the same everything
That's the kind of info that should be on these forums !!
Old Jun 7, 2005 | 02:32 PM
SmaknaSS's Avatar
What he said. /\
Old Jun 7, 2005 | 02:51 PM
Patrick G's Avatar
LS1 Tech Administrator
First off, you can't buy the MTI heads for $1,182 (that would be $1,000 less than the AFRs) and second, look at the flow difference on the exhaust. The AFRs are 20-30 numbers better at the lifts your cam would be running. The intake is a solid 10 numbers better at most usable lifts...all with a smaller, higher velocity port.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jun 7, 2005 | 03:04 PM
Sorry I posted it above, but accidentally tied it into a quote. They are the 2R heads.
Phil the MTIs are going to be for sale if you are in need and interested or anyone else for that matter.
Old Jun 7, 2005 | 03:09 PM
00RedWs6's Avatar
Do you have the original flow sheet that came with the MTI heads? If so what did they say they flow? Only reason I say this is simply because the Stage 2R MTI claims that they do 300
Old Jun 7, 2005 | 03:16 PM
Ragtop 99's Avatar
When were the MTI heads ported? Recently or is this an older set?
Old Jun 7, 2005 | 03:40 PM
I bought these from a board member so as far as flow sheets that originally came with the heads I do not have them although the advertised flow numbers are pretty accurate until about 550 and then the flow numbers take a hike as opposed to what my flow sheets shows. Neither head was able to top 300. This is supposedly a fairly new set of heads. I was told the MTIs were new but they do show signs of having gaskets on at one time. The AFRs are new.
Old Jun 7, 2005 | 03:42 PM
slow01z28's Avatar
Sent you a pm on the MTI heads
Old Jun 7, 2005 | 03:44 PM
replied
Old Jun 7, 2005 | 06:48 PM
Find me a dealer that doesnt charge you extra to have your AFR heads down to 11:1 compression, and Ill buy them. AFR come stock at 66cc, then you have to mill them to get 60cc which is about the 11:1 compression im looking for. Did you have your heads milled, or are you at the factory 66cc? that's the price savings im talking about
The MTIs are about $ 1500.00
Old Jun 7, 2005 | 06:55 PM
scalemaster's Avatar
ok so my sgt2 R heads dont flow like they say
I tought they where better
Old Jun 7, 2005 | 07:39 PM
jrp's Avatar
jrp
SN95 Director
what castings are they?
Old Jun 7, 2005 | 08:18 PM
slow01z28's Avatar
I pm him about the he said they where 241 but he had to check to make sure.
The MTI Stage 2R heads retails for $2,795 plus core.
http://www.motorsporttech.com/fbody_engine01.asp
He stated above that the heads where MTI Stage 2R
Old Jun 7, 2005 | 08:46 PM
silverTA2002's Avatar
That's kinda dissapointing.....
You have both you said.... so what kinda dyno comparison do we have? 1/4 mile?
Old Jun 7, 2005 | 09:13 PM
00RedWs6's Avatar
anyone else have any flow #s on Stage 2R heads?
