sTOCK HEADS MILLED??COMPRESSION??
Old 06-09-2005, 03:07 PM
NickcZ28's Avatar
Default sTOCK HEADS MILLED??COMPRESSION??
If I had my stock heads milled 30 thousands, what would my compression be??
also if you put 3.905 forged pistons what is your dis with stock heads??
Old 06-09-2005, 04:28 PM
Stroker 1500's Avatar
every cc is around .1 point in compression
Old 06-09-2005, 09:52 PM
RED98WS6's Avatar
Actually, it depends on many factors such as cid, head cc's, etc.
Here is a calculator:
http://www.c5frc.com/calculators/Com...Calculator.htm
Just subtract 30 thousands from your gasket thickness to get an estimate...
Old 06-09-2005, 09:54 PM
Jared H's Avatar
Did you intend to say ever .010 milled off gives .1 pt increase in compression?
Old 06-10-2005, 08:31 AM
NickcZ28's Avatar
and does angle milling do a but number on the cc of the chambers??
Old 06-10-2005, 09:06 AM
PREDATOR-Z's Avatar
Every .006 mill is 1cc, so (LS1) 66.67cc - 5cc = 61.67cc head
With stock GM graphite gaskets you'll be at ~11.0:1 SCR
Old 06-10-2005, 10:25 AM
ArcticZ28's Avatar
The calculator differs... it calculates 10.7:1 for those numbers.
Old 06-10-2005, 10:45 AM
PREDATOR-Z's Avatar
Head CC volume vs Compression Ratio:
______________________________________________
The below CR numbers are with the stock GM 5.7L displacement LS1 graphite head gaskets installed.
Installing the thicker 2003 GM MLS head gaskets will decrease your compression ratio by approx 0.1 - 0.2
72.27cc = 9.1 CR
71.71cc = 9.2 CR
71.05cc = 9.3 CR
70.59cc = 9.4 CR
70.03cc = 9.5 CR
69.74cc = 9.6 CR
68.91cc = 9.7 CR
68.35cc = 9.8 CR
67.79cc = 9.9 CR
67.23cc = 10.0 CR
66.67cc = 10.1 CR (stock LS1 head spec)
66.11cc = 10.2 CR
65.55cc = 10.3 CR
64.99cc = 10.4 CR
64.43cc = 10.5 CR (stock LS6 head spec)
63.87cc = 10.6 CR
63.31cc = 10.7 CR
62.75cc = 10.8 CR
62.19cc = 10.9 CR
61.63cc = 11.0 CR (61.67cc would be a micron less)
61.07cc = 11.1 CR
60.51cc = 11.2 CR
59.95cc = 11.3 CR
59.39cc = 11.4 CR
58.83cc = 11.5 CR
58.27cc = 11.6 CR
Old 06-10-2005, 10:49 AM
ArcticZ28's Avatar
72.27cc = 9.1 CR
71.71cc = 9.2 CR
71.05cc = 9.3 CR
70.59cc = 9.4 CR
70.03cc = 9.5 CR
69.74cc = 9.6 CR
68.91cc = 9.7 CR
68.35cc = 9.8 CR
67.79cc = 9.9 CR
67.23cc = 10.0 CR
66.11cc = 10.2 CR
65.55cc = 10.3 CR
64.99cc = 10.4 CR
63.87cc = 10.6 CR
63.31cc = 10.7 CR
62.75cc = 10.8 CR
62.19cc = 10.9 CR
61.07cc = 11.1 CR
60.51cc = 11.2 CR
59.95cc = 11.3 CR
59.39cc = 11.4 CR
58.83cc = 11.5 CR
58.27cc = 11.6 CR
Try using that calc that was posted. See if you can get the numbers to work out. I'm just trying to clear up if this calc should actually be used by anyone, and why the numbers differ.
Old 06-10-2005, 01:02 PM
NickcZ28's Avatar
So if I milled 30 thousands off and have a 3.905 bore Im at 11.0 to 1?????
what cc are my heads now??
Old 06-10-2005, 01:13 PM
PREDATOR-Z's Avatar
Old 06-10-2005, 01:14 PM
NickcZ28's Avatar
Thanx alot man does this effect HP??
