Anyone Have an overlay of 112LSA VS 114 LSA?
Old 06-23-2005, 11:14 AM
niphilli's Avatar
Default Anyone Have an overlay of 112LSA VS 114 LSA?
Just wondering about hte difference in Peak HP RPM? I am going to do a 224 camshaft. Dont want to rev it to the moon. I would love to see a dyno overlay of the same camshaft on 112 vs 114.
TIA,
-Nick
Old 06-23-2005, 02:30 PM
XTrooper's Avatar
TIA,
-Nick
Don't have an overlay, but the 112 "should" peak sooner than the 114, all else being equal.
Old 06-23-2005, 02:45 PM
PREDATOR-Z's Avatar
Yeap by about 200>300 rpm. But the 112 will make ~10 rwhp more on average under the curve.
Old 06-23-2005, 02:51 PM
niphilli's Avatar
Cool, I knew the 112 would peak sooner, but I did not realize we were talking 2-300 RPM sooner. I dont want to rev my stock short block past 6500.
BTW, here is a graph of Thunders 224 on 112
It peaks around 6100, would probably want to shift around 63,6400. I guess the 112 is right for me, you would probably want to shift the 114LSA 224 around 66,6700. If anyone has a graph of a 224 on 114 in a 346 I would love to see it.
Old 06-23-2005, 03:00 PM
PREDATOR-Z's Avatar
The peak is relative to the rest of your mods/heads/headers etc..
112 should start peak from 5800 >6000 and 114 from 5900>6100
My 224/220 116 peaks at 6100
Old 06-23-2005, 04:09 PM
niphilli's Avatar
Is that your dyno? How did you like Jeff Creech? I am thinking of having him tune my car after the cam.
Old 06-23-2005, 04:47 PM
1fastWS6's Avatar
My TR224 / 114 dyno is attached below on stock heads. Still peaked at 6000-6100. I think the 114 will peak slightly later, but have a more broad HP peak.
Graph with heads:
https://ls1tech.com/forums/showthrea...&highlight=f13
Attached Thumbnails Anyone Have an overlay of 112LSA VS 114 LSA?-tr224_dyno_sheet2.jpg
Old 06-24-2005, 05:15 AM
XTrooper's Avatar
FWIW, my 223/227 112 cam peaks at ~6200 rpm.
Old 06-24-2005, 07:01 AM
niphilli's Avatar
Can anyone overlay the two graphs in this thread?
This is interesting, if I can get the 224/224 .580/.580 on 114 to peak at 6100 I will go that route.
Old 06-24-2005, 07:05 AM
PREDATOR-Z's Avatar
It will with no advance in the grind.
The 112/114 peak is affected by other mods related to the flow in/out of your motor and by the advance in the grind. The LSA is not the only thing that determines the peak of a cam, just part of the whole equation.
Old 06-24-2005, 01:37 PM
Spinmonster's Avatar
Sux Marc but I have to agree with you on this post
The install affects the power band. If you install it dot to dot the 114 will peak later UNLESS the 114 is a 4 degree advance ground in and the 112 was zero. An adjustabe timing set would help you get the band where you want it but it sounds like you want a 112 lsa.
Quick Reply: Anyone Have an overlay of 112LSA VS 114 LSA?
