Installed Crane rockers 1.7's butt-o-meter
are they supposed to feel like a torque spike. when i go wot from a roll off first gear when i hit say between 2500-3000 you feel a big hit in torque.. my buddy was like that had to be on the juice and i was like no i wasnt? are the 1.7's supposed to gain 15-17 hp and the 1.8's gain even more?
btw: i got a check engine light but im hoping it the o2 sensor again since that has come on how many times already and i havent changed it.
You'll gain nothing.
LS1s already come with 1.7 roller rockers.
IMO, bigger roller rockers are too much trouble to change out for the small amount of power you gain with them.
Mike
Mike
Mike
Mike
Did you dyno before the installation? Just curious as to what you did gain as the 1.7's wouldn't require a major spring change like the 1.8's and I am concerned with the stock timing chain with heavier springs.
Originally Posted by 2000_Silverado_SS
I put the 1.8's on and am now .3 to .4 tenths slower. What is going on here?
Dave
Originally Posted by 99Fbody99
Valve springs not stiff enough for the added weight of the rocker
Dave
Dave
it's not the roller tip that makes the difference. it's how they come on/off the seat. the stock rockers come off the seat at 1.54 and do not reach full 1.7 until just about max lift. the vinci/crane 1.7 come off the seat at 1.79. then at about .250-.300 valvelift. they start to revert to 1.72 by max lift. the go back to 1.79 at about .300-.250 valve lift before returning to the seat. it's this desing that opens the valve sooner and longer off the seat to get more into and out of the cylinder.
Originally Posted by mrr23
that's what the rockers do. gives you more low end torque by design. i'll find the post on corvette forum where a person gained 17 rwp with the 1.7 rockers.
Thanks.
Originally Posted by My90Iroc
These were with crane rockers only? Did you gain torque? Do you have the part number for the rockers?
Thanks.
Thanks.
