Cracked block by head bolt, advice please!
nyways, has this happened to anyone else and they got away with using the block? I bought the car already modded. It was a heads/cam motor, and I guess that crack was there the entire time. I took the car to a local shop in Ohio last year for trans work, and they said it had a small coolant leak, but couldn't find it. It wasn't anything major though. And the car always ran a bit hot, at around 192 degrees. Thats with the fan switch on high and a 160 t-stat. Not sure if it was leaking coolant from somewhere else, or from that one certain spot. Any advice? Anyone got a good deal on a bareblock that they guarantee doesn't have any cracks? Thanks for any advice..
https://ls1tech.com/forums/lsx-parts-sale/345009-f-s-brand-new-ls1-blocks.html
I pass on cracks at the head stud level...
I have seen this probably 20 times. People put the head bolts or studs in without cleaning the holes out. In that 20 times it hasn't hurt one thing. One of the blocks that I used in a motor build up had a chunk missing at bottom rear right next to the rear cover behind where the flexplate would be. That motor ended up being forged heads,cam,bottle,with an auto.......that went damn fast.
What I am telling you is that it will be fine.
Id be careful trusting it too, but like a few guys said it could be perfectly fine and you might not even notice an issue with it.
