5.3 heads
Old Jul 7, 2005 | 08:57 PM
electricz28's Avatar
Default 5.3 heads
Is any one running 5.3 heads in the stage 3 configuration. What is your CR and how well does it run on 93 octane. I want to add these during my cam and intake install. I can get LTs later. Hey post up your HP # with these heads and similar mods.
TB - stock ported
Intake - LS6
Pulley - 10%
Cam - 224-112-.581
Trans - stg.1 3200 stall
Rearend - built 10 bolt-3.73
Eaton, Moser,T/A
Headers - MAC mids w/3" coll.
3" Y w/cats and c/o
Suspen. - BMR, Edlebrock
Heads - 5.3 or LS6 ?
Bore & Stroke-stock
Old Jul 7, 2005 | 09:15 PM
jrp's Avatar
jrp
SN95 Director
define "stg 3" configuration.
and compression is dependent up bore, stroke, chamber volume, gasket thickness, deck height, ect...
Old Jul 7, 2005 | 09:19 PM
Stock shortblock-
Old Jul 8, 2005 | 08:27 AM
xfactor_pitbulls's Avatar
Originally Posted by electricz28
Stock shortblock-
Stock shortblock and 5.3 heads. Anywhere from 10.8-11.1 compression. 93 octane is fine anywhere in that range. Depending on gasket and depth of mill you can get more compression if desired, but 11:1 is a good number.
Brandon
Old Jul 8, 2005 | 06:40 PM
AKRA's Avatar
5.3 heads should give you approximately 10.8:1 compression. My stage 2 5.3 heads work great with 93 octane gas.
If you think you might ever want to add a super charger or nitrous you might want the LS1 or LS6 heads. The extra compression from the 5.3 heads will only get you 5 to 10 extra hp. But if you go with a super charger or nitrous the extra compression will probably make you loose more than that.
Good luck,
Al
Old Jul 8, 2005 | 06:56 PM
Good luck,
Al
I am planning a 100 shot. Thinking maybe its a no go on the 5.3 heads. I will get my ATI Procharger some day. I have to spend the funds on things like a new roof, AC unit and it really sucks 'cause neither one of those will make my Z go faster.LMAO
